  New Posts New Posts RSS Feed - raw water pump
raw water pump
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: raw water pump
    Posted: August-15-2007 at 9:49pm
for a 1994 is needed
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2007 at 9:22am
Ryan, What is wrong with your pump? You do have one don't you? If you do have one, I know you are pretty handy so you may want to consider rebuilding. If the housing isn't busted open, then all they need is bearings, seal and impeller. There is a thread on a parts source.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2007 at 7:39pm
the previous owner must have stripped one of the blots and has finally gave way.tried having it machined/tapped and in the process it cracked in half.went out yesterday and tried it with just one blot and no success..pulley was all over the place.actually went into limp mode..hate tro spend 275 on one this late in the year
