!!!Project 80 Ski!!! |
Page <1234 6> |
racintj ![]() Senior Member ![]() Joined: May-09-2007 Location: United States Status: Offline Points: 163 |
Sorry about your Mom, and congrats on doing something to remember her.
I'm not sure how you are positive that it is standard rotation, double check and triple check that this is the case. Are you just going to put rings in it if the cylinders check out? What is the chamber size on the RPM heads? 750 is too much carb for the 351 in a ski boat. 351 ci. at 5500 rpms, with 100% VE (volumetric efficiency) is only 560 cfm. I'm suprised doc didn't jump on that. What kind of lift, duration and overlap are you running? Solid lifters, I guess you like adjusting valves. |
Every day above ground is a Good day.
Lakeland, FL |
MarineSRT8 ![]() Senior Member ![]() Joined: August-06-2007 Location: IN/FL/SC Status: Offline Points: 227 |
Intake duration of 291 and an exhaust duration of 311, intake lift of .541 and exhaust at .526 and a lobe seperation of 107 deg. which means I am safely clear of the 115 deg no no zone. I do however understand that my (VE) is at about 134% at 5500 rpms with the 750 carb...BUT I will be spinning faster than that. More to the tune of 6000. The (VE) of 134 is with the carb spraying static. So with the carb bridled a bit I will have no problem getting pretty close to 100% (VE). No I dont mind adjusting valves and with the limited time the boat will be in the water the adjustments will be minimal. Besides it will grab RPMs alot faster than a Hyd-Lifter motor.
"Some people go an entire lifetime wondering if they made a difference. Marines don't have that problem"
-Pres. Ronald Reagan- ![]() |
MaddMarxx ![]() Platinum Member ![]() ![]() Joined: June-29-2006 Location: United States Status: Offline Points: 1741 |
thats a stock 351, 6000-rpms not for long, Boom!!
have you been building motors for long?...Because if you know what you are doing....6000 rpm is not a death certificate.....like I posted earlier I built a 383 that would spin to 8 grand if need be....and its still going strong with many trips to the strip
racintj, did not chine in on this issue as i was not going to be the one to piss on his parade.
The cam and induction system will work great for a 1/4 mile car running 4.56 gears, for a short time .But soon MR. Squeeky will come to call,bottom end failure. I see lots of issues,rotation I am not sure of,cam too muh bump,carb too large, incorrect rotating assy.for said RPM's,and largly understanding how a boat engine works VS car motor immense. But the proof will be in the pudding. If he can prop it afterward that alone will be a story for this site. If my prop math is correct; If the motor will pull a 13x14 /6000rpm's =68mph that will be a fast C/C....good luck..boat dr |
p/allen ![]() Gold Member ![]() ![]() Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
Doc He will never get 68mph out of a nautique. He will have to prop it down if he wants 6000 rpm . He may need a 13 x 13 or maybe even a 13x 12 1/2 . Is that the acme 541? He will have one hell of a hole shot .
You all are proving to be awesome arguees. I love it. I guess I must have been born yesterday because with my...."Immense" lack of knowledge on how an engine works I must be making up stuff when I say that an internal combustion engine does the same thing as another one....hmm...what an amazing discovery!!! we reallized that a carb supplies fuel and air...plugs ignite it...and the pistons move....WOW....Ok so the prop post knowledgeable, yes. But come on doc gimme somethin to work with your proving to be an easy target
87BFN owner ![]() Grand Poobah ![]() ![]() Joined: August-25-2006 Location: Ypsilanti, MI Status: Offline Points: 2194 |
Eric
I don't agree with you on your post implying a gear to gear timing assembly will not hold up to high rpms. Please correct me if you ment something else. But every engine builder I know, goes gear to gear on timing when you really want to spin a motor at high rpms. Plus the rotating assembly should be balanced also. P/allen I agree 68mph he wont see, the 351 just not capable of pruducing enough torque to spin a prop at 6k with out backing off some of the bite. Which is why I have this question why spin the motor any faster then you need to if there is not going to be a gain of some sort whether it be out of the hole or top end speed? |
Boat doc wrote
Some the parts you have bought will work.The rear seal is specific to rotation,as is piston rotation.The cam is a LH, or convetional,and will not work with a RH or reverse rotation dist. Boat doc why do you say pistons are specific to direction of rotation? I am asking a question, I am not saying your wrong. I am not new to engine building just new to marine engine building. |
Ive heard that for some reason on the RH rotation that the pistons need to be installed backwards with the notch that is in the piston pointing towards the back . Look at thepistons again and check it out .
I dont know why . Its just what Ive heard . I just noticed in your 5th pic that the notches are going to the front . |
Yes I may be an easy target for the sharpshooter you are.Just fire away,I know very little about motors and boats.I just post on this site because of my illness.I get caught ,and the real me comes to light for all to see. As i write this I am in solitary lock-down.It gives me a way to pass the time till my next parole hearing. Sorry to have suggested that you were less than knowledgeable about building a 6 grand tow boat motor.Sometimes the MEDS,heavy doses by the way,don't seem to work. Sorry to cut this short,but it is time for a shake down,A knife is missing from the kitchen, and i have not hidden it well...........boat dr |
Wow.....I love this place.
Where is 79 when you need him? john |
Marine, don't take this the wrong way, keep your head high and take the punishment. I think the majority of us have had to suffer thru it. I know I did. Really, you need to take into consideration the info given. I have built many motors that go in fast cars and race cars, but I still didn't understand many characteristics of these boats and motors. It will be pretty hard to turn that motor to 6000, especially with the stock bottom end. And if you do turn it, it will be about 1000 wasted rpms. As doc stated, the efficiency of these boats and props drastically reduce past the 5000 rpm range. I also doubt very seriously that you will have a VE of 100%. You may prove us all wrong and make a 70 mph ski boat, then we will all eat crow. We all know that torque and HP always equal at 5250 rpm, so build a motor that has 300 ft/lbs of torque buy 2000 and keeps increasings to 5000, have HP and torque meet at 5250 with 400/400 tq/HP...that my friend would be a happy boat.
Lakeland, FL |
nautiquefanatic ![]() Gold Member ![]() ![]() Joined: April-29-2004 Location: North Carolina Status: Offline Points: 570 |
MarineSRT8 / Nate,
Before you get too carried away with the motor work, please go inspect the prop on your boat. You have a reverse rotation, RH motor in the boat. This was STANDARD in the 80 SN. By reverse rotation, we mean OPPOSITE of a car. Not wanting to add to the argument, but go look at your prop, it will tell the tale! I should know, I used to own the boat you are working on, I sold it to the man you bought it from.....and I have plenty of photos of it, one showing the prop and the fact that it spins RIGHT to propel the boat forward. As stated earlier, this will make a difference in the parts you have purchased. pc |
SRT8; As in a post before, show us a pic of the distr. shaft or the prop.Or better yet, give us a close up of the pump housing, this will tell you all you need to know.
You are smarter than the rest of us ,this I understand, but show us some pics. Better yet,see if the cam shaft you bought will mesh with the distr. drive gear............boat dr |
M8, Pleeease read and heed. When a body has put everything else together with patience and care, and then he goes to drop the distributer in...?!!? At that particular moment in the space-time continuum, LH and RH become VERY clear! LOL Guess how I know! ...and I'll tell that story later ![]() |
First of all doc you are hilarious. And all of you guys are awsome!! You have all given me info that I would have not recieved anywhere else. Yes I do know the boat was a RH at birth but I am going with the 1.23:1 tranny and spinning her the other way. I figured that tranny would give me a little more room to stretch her legs. My last post of yesterday was not to downplay anyones konwlegde. I do understand an engine spinning a prop and and engine spinning a rear end and tires react very differently in many situations. Keep coming with the info and posts though its all keeping me motivated to stay on top of the project.....and by the ay Doc, I laughed out loud by myself at your post.....pretty funny
Glad to know you are on top of it. I will tell you though, it seems you are going a long way and spending plenty to NOT rebuild the bottom end. A fresh set of slugs (hypers that MM has for sale), ARP rod bolts, polish crank, and hone the block wouldn't be more than a few hundy. Then you could balance the crank, rods, and pistons as well.
Lakeland, FL |
I apologize for leading you all astray. I mentioned earlier in the thread that the block pistons crank and a few others are currently at the machine shop.I did however forget to mention that the crank is being polished and balanced, new bolts, bearings etc. are in the makings of this motor.
And with that heres a few for to keep everyone updated on her progress. Hey look factory interior hiding under there!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
I saw that CCF links Barts Watersports....reminds me of home. The lake I go to is in the town where Barts is based.
Glad to see that you have it pointed between the markers!
Looks like you have plenty to keep you busy, but it also looks well on the way...and pardon me if I spoke out of turn. Can't wait to see the end result...especially because you're doing it in honor of your mom. Ms. Buffalo and I are guessing she'll approve. ![]() |
And how many quarters?!!? LOL
hey thanks BFN Im sure she'll like it too. Yes, I am well on the way but right now the light at the end of the tunnel is very very dim lol
And here all this time I was thinking that the Doc had slept in a Holliday Inn last night ... LOL!! |
scott8370 ![]() Gold Member ![]() Joined: November-30-2005 Location: United States Status: Offline Points: 872 |
Wow!! You got a project. Keep the pictures coming. With it stripped down to the bare hull, you won't have many surprises.
Scott
Marine, I just thought of something that hasn't been mentioned in this post, and I don't know if you are familiar with. Make sure you tell the machine shop that you need piston to cylinder wall clearance to be double of a street motor. There are threads on here that talk about this, and many bad experiences of motors that were built by reputable street builders. Motor always under load (pistons heat and expand), block constantly cooled by lake water (stays cool, less expansion) = more clearance needed. Good luck, just thought I would try to help.
Lakeland, FL |
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6119 |
Hey, Scott, Good to hear from you. I was just thinking of you the other day. Maybe you've been posting and I've missed them. But I was thinking just because you had to ease up on the fiberglass and paint work, that I hoped you werent going away. I still think that torino you did is one of the finest boats on the site, although I am partial to torinos. Do you keep in touch with the new owner. He lovin it?
The Dude ![]() Platinum Member ![]() ![]() Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
Marine, Wawasee? Dewart? Syracuse?
Mullet Free since 93
95 Sport |
WEll little over your head but we'll see. Way to much cam, you over look several key issues as well. I don't believe the tranny you are going with is the best choice for the power you are trying to throw at it.
reidp ![]() Platinum Member ![]() ![]() Joined: December-06-2003 Location: Mooresville, NC Status: Offline Points: 1804 |
I just hope that thing isn't coming to Green Lake next summer. Looks like 400 HP to me.
But Nathan, if I could I'd like to throw out several issues for more discussion if it's not too late: The 1.23 trans and stretching her legs I feel are not hand in hand. The 123 will allow her to squat, grunt and sprint a short distance quickly with lots of authority, while a 1:1 with a smaller dia/higher pitch prop will typically make the most of a higher rpm engine, i.e., most speed in a lighter boat. If your cam is the only direction-specific part you've bought, then RR is still your best direction in this hull. At least CC thought so, and I know you've probably heard or been told that it will list to starboard with a LH engine. It will. As for RPM, it'll turn what it can with a 13x13 or 13x14 depending on prop design/brand. By that I mean you won't prop it with the intentions of making it get to 6K, but more so prop it as you would with a typical 350-351 ci engine. Then let the cam, heads, and other mods take it from there, and see just what it will turn, 6K or whatever with a max of around a 13x14 prop. THEN step up the prop (more pitch) and see if you can lower r's and gain speed, and thus find out what your combo's sweet spot is for making the most speed. Even though this pkg would want to turn 6500-7000 thru the gears in a car to get the max in terms of 1/4 mile acceleration, in a boat for max top speed the ideal rpm is typically somewhat reduced down towards that HP/torque intersection racintj mentioned. In the meantime thanks for volunteering your efforts and funds as our newest guinee pig. It'll be fun for all of us...............until next year's reunion. |
Page <1234 6> |
