Airguide speedometer lens |
Sam B ![]() Senior Member ![]() ![]() Joined: November-17-2007 Location: StevensPoint WI Status: Offline Points: 393 |
![]() ![]() ![]() ![]() ![]() Posted: February-01-2008 at 11:41pm |
Does anyone have a glass lens for a airguide speedometer that I can purchase? I hate to spend big dollars on a guage when I just need a lens.
Thanks Sam |
anthonylizardi ![]() Gold Member ![]() Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
Sam,
It all depends what type of speedometer you have. I have an SN 87 and the glass are removable. They are cracked so I need to replace them. Somebody suggest to replace them with a watch glass. Those are the crystal glasses you use on chemistry glass. I bought them online only for a few dollars. You will still need to buy a diamond drill bit to make the hole for the adjustment. I measure the old one and I was able to find the same size. Good luck. |
BTW, this is the place I bought them. They cost less than $2 each. Chemistry Watch Glass
Regards, Anthony |
Anthony,
Thank you I am going to order today look perfect. Thanks again Sam |
Sam,
Glad to hear that will work for you. FYI, the diamond drill bit I bought is for my dremel. I guess you want the speed. I haven't done mine therefore I don't know how hard is to drill a hole on glass. It shouldn't be, I hope. That's why I bought four in case I screw up ![]() Good luck, Anthony |
