Spark Plug Wires |
Greg_SA
Senior Member Joined: April-19-2007 Location: South Africa Status: Offline Points: 183 |
Posted: February-07-2008 at 5:11am |
Hi,
I need to replace my spark plug wires... Can anyone recommend some? I could order from Skidim, but I'd profer to buy from a local auto store (I live in South Africa). Can I buy automotive ones? If so, what model car should I specify? Thanks, Greg |
SkiBum
Gold Member Joined: November-17-2006 Location: United States Status: Offline Points: 587 |
One problem with using automotive wires is that they may not be long enough because of the exhaust manifolds. If you wanted to go that route you could buy one of those 7mm or 8mm universal wire kits where you make the wires the length you need.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21192 |
This is what I did. I bought some Taylor Spiro-Pro 8mm universal wires and terminated them myself. Piece of cake. |
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
Tim,
Are running a DUI ignition too? I guess you got the 90 degrees ones for a V8. |
I am. IIRC, the universal kit comes with bother terminations (90deg and 135deg), and you cut off whichever one you dont want to use. You then have the choice to terminate with either the male or female terminals (both are supplied) depending on whether you have a Ford or HEI style dist.
boat dr
One word of caution here tho:
Buy a good set of crimpers that have the dies for insalling the terminals.I have a set of Beldens that have served me well,but even these can be tricky at best. Making that initial roll can be a bitch, and the end result is determined by this first step........Boat dr |
M3Fan
Do you need a special tool for the Taylor universal kit?
boat dr
If it is a custom set, you will have to install one end on the wires.
Herein lies the use of the terminal pliers, and the ones that most people have are not suited to be used with spark plug terminals. A pair of pliers will work, and brain surgery can be performed with a hack saw.Just have the proper tools to properly do a job............Boat dr |
Greg_SA
Hi,
Thanks very much for the replies :) My best best is probably ordering a set from Skidim. Our local auto parts store can also match up individual wires, so I might try that too. Cheers Greg |
Like Doc said. I bought a tool at NAPA ($8) that specifically had the spark plug crimper built in. Now Im good for the next time I build a set... assuming I can find it. |
another little trick to expose the core is to use a coax cable tool to strip the wire and expose the the core that should be folded over before it is crimped. Wire stripers don't work very good on silcone jackets as there is too much give on them.
