  New Posts New Posts RSS Feed - PROPS FOR BAREFOOT NAUTIQUE
QUEBEC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Topic: PROPS FOR BAREFOOT NAUTIQUE
    Posted: September-12-2009 at 12:03pm
HEY, ANYTHING NEW ABOUT PROPS OUT THERE FOR MY 90 BAREFOOT NAUTIQUE. WHAT WORKS AND WHAT DOESN'T?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2009 at 1:44pm
Which engine (330hp 454?) and which tranny (BW 1:1?) do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2009 at 2:32pm
RH 3 or 4 blades work good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2009 at 9:24pm
454 PCM 330 HP TRANS 1.1
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2009 at 9:30pm
Acme 1598
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2009 at 11:31pm
HOW DOES IT WORK FOR YOU
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2009 at 11:47pm
AWESOME
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 12:40am
OUT OF THE HOLE / TOP END / WAKE TABLE / POWER BAND ????
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 11:26am
ALL AWESOME
ejojprop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ejojprop Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 11:41am
OJ 13 X 14 RC 1" 4-Blade, worth a try.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 11:54am
Eric, you have anything in the XMP line that will work? Preferably a 3-blade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ejojprop Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 12:17pm
No 3-blades in the XMP's. Have a 14 X 14 RC 1" 3-blade. The 13 X 14 4-blade has worked well too.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 12:23pm
So you do have a 13x14 XMP, its just a 4-blade? How much cup does it have? The 14x14 may be a good option for Quebec, but the 79-80 BFN's (like ours) doesnt have the notch in the keel and cant fit a 14" diameter wheel. Im curious how the OJ would compare to the Acme. Im seeing about 56mph at 5200 RPM with the 1598 equivalent that Im running now (13x14, .080 cup).
Post Options Post Options   Thanks (0) Thanks(0)   Quote ejojprop Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 12:40pm
The 13 X 14 RC 1" 4-blade is from the FORCE line, not an XMP. It can have any amount of cup, .090 is standard. Don't be afraid of the FORCE props, they are created from CNC machined patterns and then hand crafted. Hand crafted does not mean we change the propeller in the finishing process, we are just cleaning up the casting, not changing the accuracy of the part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2009 at 10:12pm
I HAVE THE 14X14 STOCK PROP NOW ON THE BOAT RUNING ABOUT 49 MPH. JUST LOOKING FOR A GOOD PROP THAT WILL HELP THE PERFORMANCE OF THE BOAT ALL AROUND. NOT JUST IMPROVE ONE THING
Post Options Post Options   Thanks (0) Thanks(0)   Quote ejojprop Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 9:19am
What is the max RPM that prop will turn? Is it a Michigan Wheel?
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 11:36am
Tim, in your opinion, what would happen to your performance with the 1458 vs. the 1598... the 1458 having the larger cup.
Craig
67 SN
73 SN
99 Sport
85SN
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 12:25pm
I tried the 1458 and then dinged it up (dont ask)... when Acme repaired it, I had them recup it to .080, so its essentially a 1598 now.
I think the 1598 is the way to go. It gets the revs up (~300), which should improve the performance of just about every 454. If you stroked it to 502, etc, then it may be beneficial to lower the revs in order to gain speed. Our BFN breathes better than average (56mph @ 5200 RPM with the 1598) and the overall performance is great with this prop. I cant imagine youd want anything different with a stock motor- and definitely not something steeper (more cup or pitch).
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 1:39pm
I'm luvin' this thread. I have some prop tinkering to do to catch up with Tim!
Amy, all I want for Christmas is...
1988 BFN-sold
skicat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 2:48pm
Ok Tim. My 1598 is on the way to replace the 4 blade that somebody abused at GL this year (no names mentioned right Tom). Acme agreed the 1598 should work well & up my rpms that I need.
Greg
86 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 2:54pm
The stock 81+ (notched keel) 330hp 454 prop would be a MW 14x14 3-blade.
kytom2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 4:33pm
I get the blame because someone else stops the boat in 2 foot of water and says "here you drive awhile".
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 5:13pm
Yikes; the draft on mine is listed at 26". I found out how much BFN's hate shallow water at the river last year...also how important markers can be!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote kytom2 Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 5:24pm
Actually the depthguide said 4 ft of water...but it obviously lied!
Post Options Post Options   Thanks (0) Thanks(0)   Quote QUEBEC Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2009 at 10:07pm
ABOUT 4800 RPM
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2009 at 12:23pm
Thanks for the input Tim. Yeah our's is bone stock, runs very well, however max RPM with the current prop is around 4300, quite a bit less than your 5000+. According to the manual though, mid 4k's is right where the max RPM should be for the stock motor. I was mainly trying to decide which one (1458 vs. 1598) would be a better fit for our setup. We use the boat for about 80% slalom, 15% cruising, 5% other.... and I didn't know which arguement to use.
The 1458 would probably lower the RPM's a bit at any speed, maybe being a tad more fuel efficient. Don't know about top speed, and don't really care all that much about it.
The 1598 would pull out of the hole better, get into the power range of the engine a little more at slalom speeds and make it easier to maintain speed (no perfect pass . But would cruising around be less efficient with this prop?
The stock prop our BBC SN is a Fed. 13x15. I would think both of these props would definitely be light-years ahead of this (especially since our's has several nicks/dings), but I'm just trying to figure out which one to pull the trigger on.
Craig
67 SN
73 SN
99 Sport
85SN
wakeboardin2k4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2009 at 1:03am
c-bass what did you decide? And were you happy with your choice?
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2009 at 1:46pm
On a stock 454, youd be crazy not to go with the 1598. It will turn ~200 RPM more than the 13x15. The 1458 would turn about 100 less. These comparisons are based on a really dinged up 13x15 Fed, but for as bad as it was, it still pushed the boat to 53.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2009 at 3:43pm
Yeah I'm extremely close to pulling the trigger on a 1598...especially with Delta's 25% off they're currently running. I just gotta clear it with the "accountant" ...
No matter what I do though, I won't have results until next spring. The boat is asleep for the winter.
Craig
67 SN
73 SN
99 Sport
85SN
84BF454 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84BF454 Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2009 at 2:07am
I have a shaft for a 84 barefoot for sale!!!!
msa84bf454
