  New Posts New Posts RSS Feed - 2001 Super air w/Gt40 - Ground locations
2001SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Topic: 2001 Super air w/Gt40 - Ground locations
    Posted: June-16-2013 at 6:42pm
Anyone able to point me to the grounds in my boat so I can give them a clean. I'm having a few twitchy guage needles.
D.
A little knowledge is a dangerous thing...
2001 Super Air Nautique
1989 Fairline Corniche 31
www.bannrivercruises.co.uk
flipflop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flipflop Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2013 at 1:57pm
Not sure how different a 99 is to an 01, but I just cleaned mine recently. I believe there is a wiring diagram out there for your dash if needed.
Two on the bell housing at 11 and 2
One on the starboard engine crate
Dash gets ground from wiring harness
Clean terminals in dash
Good luck
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2013 at 9:21pm
Darren on a centre mount GT40 there are some extra earths on the passenger side at the back of cylinder head. These are the earths for the ECM and other engine components. I assume the Vdrive and centre would have the same GT40 engine wiring harness.
The main earth from battery is on drivers side bell housing as mentioned. The dash earth comes via the 10 way harness plug at engine and at the dash. Give both sides of the harness plugs a clean and coat with some dielectric grease.
The dash wiring is just crimp connectors check all the ground wires at the crimps. Remove any suspect crimps with soldered connections and heat shrink.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2013 at 10:19am
cheers lads!
have a good weekend.
