OIl/Trans fluid |
Page 123> |
Author | ||
Cumby ![]() Senior Member ![]() ![]() Joined: February-03-2014 Location: Upstate SC Status: Offline Points: 209 |
![]() ![]() ![]() ![]() ![]() Posted: August-03-2015 at 6:17pm |
I've been reading some posts on different types of oil and the additive requirements. Can anyone give me a short list of the best oil and weight to use for a 99 GT40. I'm in SC. Also, anything special about the transmission fluid? Is it a best practice to change both when winterizing or is it OK to change them close to the end of the season and then still put some hours on before winterizing?
99 Ski Nautique GT40
a0128 ![]() Senior Member ![]() ![]() Joined: May-05-2014 Location: Oregon Status: Offline Points: 226 |
For your 1999 GT-40 you will want to use an oil with a high zinc concentration. A ZDDP number of 1400 ppm is best. I use Valvoline Racing Oil 20W50 in my GT-40. I believe the original recommended oil was 40W40.
Changing your engine oil and transmission oil every 50 hours is recommended. Someone else will need to chime in on the exact transmission oil to use. Originally it was Dextron II IIRC however I believe that is no longer available. |
Dex III is backwards compatible (OK to use). I believe schedule is 100 hrs for tranny.
Toertel ![]() Gold Member ![]() ![]() Joined: August-26-2013 Location: Atlanta Status: Offline Points: 775 |
I use Rotella T 15w30 (right Zach?) and Dex 3
Oil and filter every 50 hrs and Dex every 100 |
1994 Sport Nautique
The manual does recommend 40w40 although I don't know if that's GT 40 specific? It also lists 20w50 for below 32 degrees temps. Just wondering why you choose 20w50 other than valvaline racing not being available in that weight? |
Always have had good luck with 20W50. Sometime 40W is hard to get, but it is available in the Racing Oil flavor. |
JPASS ![]() Grand Poobah ![]() ![]() Joined: June-17-2013 Location: Orlando Status: Offline Points: 2283 |
I use Mobil 1 15w50 every 50 hours with Mobil 1 filter as well.
Castrol Transmax Dex/Merc every 100 hours |
'92 Correctcraft Ski Nautique
Is 40w40 the same as ae40 now?
Nautiquehunter ![]() Platinum Member ![]() ![]() Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
Mobil 1 15w50 and any dexron compatible trans oil every 50 hours on both.
I decided to contact PCM. Their recommendation for oil was the Rotella 15w40.
See close enough...I did not have the can infront of me. I buy it at WallyWorld |
1994 Sport Nautique
...and he did say Dex 3 for transmission.
I give up
shierh ![]() Gold Member ![]() Joined: April-29-2015 Location: Florida Status: Offline Points: 605 |
rotella is about the best conventional oil there is. its diesel oil but is also excellent for gas engines. im going to use it in my new rebuild. I use amsoil in everything else.
8122pbrainard ![]() Grand Poobah ![]() ![]() Joined: September-14-2006 Location: Three Lakes Wi. Status: Offline Points: 41040 |
Glen, What brand of car(s) do you drive? I'm just wondering if you've called GM, Ford, Chrysler, etc. regarding the brand??? I feel you should call PCM back and get the recommendation is writing. You talked with someone and got a PERSONAL opinion!!!! ![]() |
Then educate me Peter...please. That's why I joined this forum! I don't want to get in a bunch of debates. Just want to know how to properly care for my boat.
Oh, and I'm a Toyota guy ![]() |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2880 |
I use Royal Purple HPS™ – High Performance Street Synthetic Oil in 20W-50 for the engine. I also use the K&N oil filter (number 3001).
The topic of ATF will likely get a little debate. Friction modifiers, synthetic vs. non-synthetic, etc. Lots of folks here use Valvoline Dex/Merc ATF. JQ |
Most automotice OEM's specify an oil weight and give a brand recomendation...
So whats wrong with calling PCM and follwing their recommendation? Byt the way, I followed Zach's recommendation which was also Rotella... |
1994 Sport Nautique
Glen,
The brand comes down to your choice but the key is to make sure it has the proper levels of ZDDP. I've been running Valvolene racing 20-50 in all my boats for years. |
Rob, Doesn't the work "street" indicate there isn't ZDDP added? Is there any and do you know at what levels? |
So weight doesn't matter??? I've seen a lot of different personal opinions on different weight oils. That's why I went back to PCM since I didn't see much/any available in 40w40. |
Neither Ford who actually built the engines nor PCM who is mearly an engine conversion company has tested or have had one of these engines in their hands for something like 15 years. When they did oils were designed for flat tappet engines.. Since these engines were discontinued,the oil specs have changed. Why would they have kept up with oil technology for an out of warrantee past product? They do not even support them for parts,they are in the business of making a profit selling new engines. But take their word as gospel over multiple people who have current experience using current oils in older engines would IMHO false security. I would not call Ford to ask what to use in a model A anymore than I'd call at&t and ask what the best rotary phone is. |
Orlando76 ![]() Grand Poobah ![]() ![]() Joined: May-21-2013 Location: Mount Dora, FL Status: Offline Points: 3108 |
I don't know the specific ZDDP additive level. Based on Royal Purple statements, the oil does contain zinc and phosphorus. To quote from the Royal Purple website: "Royal Purple HPS Series motor oil is specifically formulated to maximize performance and meet the demands of high performance and modified engines. HPS is recommended for vehicles no longer under manufacturer warranty and for those seeking a higher level of performance and protection. This unique blend enables HPS to outperform leading synthetics and conventional lubricants for both gasoline and diesel engines. Royal Purple’s HPS is fortified with a high level of zinc/phosphorus anti-wear additive and Royal Purple’s proprietary Synerlec® additive technology." I like the Royal Purple stuff. I've also used Mobil 1 Racing in 15W-50. |
For more information than you could ever possibly digest, try:
Bob Is The Oil Guy website. Lots of good info there, but you need to sift through some background noise. JQ |
So why do you guys choose a 50 weight oil when 40 was the original recommendation? Is that based on anything objective, or just preference?
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13512 |
Because Valvoline doesn't make a multi viscosity VR1 40 weight
oil is such a hot topic, you should visit a Harley Owners site some time. people about kill each over this topic.
Im guessing those running 20/50 are using synthetic which flows much better than conventional oil, likely the reason for the heavier weight over the 40. These engines work hard, much harder than car engine. I would guess that 15/40 Rotella or 20/50 pure synthetic would be the best oils to use. EPA controls the additives in oils. I'm guessing that oil branded as Racing likely circumvents EPA as does Diesel oil. Anyone know of any facts around this? |
So, just to make sure I'm understanding you, you're saying the brand of oil is more important to you than using the manufactured recommended weight? Not trying to be smart,,,really want to understand why you guys use what you do. |
Page 123> |
