  New Posts New Posts RSS Feed - Another BFN Prop Question....
 Post Reply Post Reply Page    <12
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:02pm
side note: 644 has to much rake so the shaft will need to be shortened.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:09pm
Acme 328 is what most are putting on their V-Drive Excel/BFNs......Mainly that's because there is a clearance issue.....they are thinner and fit between the shaft end and the rudder. My prop shaft has been shortened...I "should" have a greater choice because clearance isn't an issue.....but it may change the way the prop performs too....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:11pm
I think anyone attempting to get the most out of their BFN/Excel would best be advised to shorten their shafts up as much as possible (~1/4" strut to prop hub clearance). That alone would offer some performance benefit- and it it opens up prop choices, even better. I am not a big fan of the "pancake" props if youre looking to optimize top end... and the BBC boats that are pushing 50mph are probably amongst the ones that might benefit from the props with more rake.
Steve, the more common "raked" Acmes (as opposed to the "pancakes", which it sounds like what the 380 is) will raise the bow slightly at speed, increasing top end.
An extreme example, but the 1868 I tried on our '79 (also a pancake) did a dangerous nose dive at speeds above 50mph and clipped 5mph off the top speed. I wouldnt expect to see the same results on a lower powered, v-drive (especially with the heavy back end), so Im sure they wont be dangerous- but probably not as good of performers as the raked props.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:36pm
So...Putting this all together once the RPM issues are resolved and since I should have clearance....
Looks like the 644 is the prop to try....or the 328? Is there a big enough performance benefit going from the 1160 to the 644 to warrant the cash difference?
I agree Tim, I don't think nose dive is an issue..... too much bow rise is usually the big issue with these guys......
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:43pm
That'd be a question for Tim. I would say probably being that a .135 is a pretty big cup and you are dropping 1/4 inch in diamater. I would say that all together may net 300-400 rpm at wot? I could be wrong, Tim is prop Jesus.
With what Tim says the 328 is a bad deal for higher speed boats. Causes nose dive at speeds becuase of the reduced rake.
We have a very nice red footer with the 328 on it in the shop but It has a little old 351 in it.
I I have a freshly rebuilt 380 I just posted in the for sale if that seems to be a good choice. I also have the 504 which is the same specs but I couldn't find cup on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:49pm
Well now thats weird. Scratch my last post. The 380 I have in my hand says its a 17.5 pitch as well as the odd 504. Hmmmm does not match the Acme 380 prop listing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:50pm
Im saying that pushing the nose down may in fact be an issue. It will only be an issue at WOT, and will not affect bowrise during holeshot. As you approach the 50mph mark, the more likely that blade rake will have a significant affect on top end. While a pancake prop is unlikely to cause a dangerous bow plant, I suspect it will in fact cause the boat to run more level, and probably trim some speed. Not 5mph perhaps, but 1-2mph is certainly plausible.
No, if you have a 1160 now (13.5x16 4-blade) then the 644 (13.25x16 4-blade) would not be worth trying... UNLESS you can confirm with Acme that they differ by more than just 1/4" of diameter. IE, if the 1160 is a pancake prop and the 644 is not, then the 644 should perform a little better.
The 380 (13.5x17) might be fun to try IF you can confirm that WOT rpm's are a good bit too high right now. Say, 4800rpm or higher. Expect it to trim ~400rpm off your top end... so if it puts you squarely in the 4400-4600rpm range, that would be ideal. It will hurt your holeshot, though.
Either way, dont go spending a dime on any props until you verify what your WOT rpm's are. Without that piece of info, it would be a complete shot in the dark as to what will work better.
If you confirm that the 1160 is NOT a pancake prop, and you find out your RPM's are already in the 4600rpm range, then you may be propped ideally already. In which case, you may want to be looking elsewhere for your lost speed. (I would not be surprised if this is the case.)
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:54pm
Just a note, the 380 is not a pancake
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 3:58pm
The 380 I have must be an older version when they ran a 17.5 and not 17.0.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 4:12pm
Acme 380, 13.5 x 17.5 .105 cup 1.125 dia rh? Does this match?
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 4:15pm
Matches mine yes but the list Tim posted directly off the Acme site say 17.0.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 4:21pm
Ew I see now hmmm, wouldn't change much I suppose. Mine was a rebuild from delta I got for $280 although sold the boat and heard it became an excavator so he may be in the market for yours
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 5:14pm
Its possible that Acme's application chart is wrong... the 381 should be the LH version of the 380, and its listed as 17.5".
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 6:11pm
Must be Tim. typo!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 6:39pm
Zach:
Where does the 504 fit in this discussion..... I don't see it on the ACME chart?
Thanks guys...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 6:59pm
If its not on Acme's application chart, then its either brand spanking new or obsolete/NLA... most likely the latter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 7:21pm
It's NLA it was a prop they made especially for nautique that had the logo on each blade (kinda cool!). It's same spec as the 380 but I haven't been able to come up with a cup spec for it. We will know a ton more about possible prop choices this spring when we get marks 91 Footer back on the water.
Orrrrr is it a super double seceret stealth barefoot prop espeically built for 91 454 bfn's at n3......... Muahawwahh!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 7:35pm
Orrrrr is it a super double secret stealth barefoot prop espeically built for 91 454 bfn's at n3......... Muahawwahh!!
Nautique Logo...Super double secret stealth prop.... Sounds Awesome! Put my name on it until I get my rpms figured out! Ha.............
Thanks fellas - it gives me some good info to think about as we go through the boat this winter...........
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 8:03pm
The boat will be so fast you may get pulled over and be put on double secret probation!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2012 at 9:00pm
We get by in the Barefoot without the Water Cops ever taking any notice....but as soon as we are out on the Air206...the Water Cops begin profiling and we are afforded no end of "Courtesy Inspections"...
Double secret probation doesn't scare me....were we scared when the "Germans bombed Pear Harbor? NO! ".......? Ha, LOVE that movie!
