  New Posts New Posts RSS Feed - Damaged 1974 Mustang 17
 Post Reply Post Reply Page    <12
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 9:36pm
Yes, the prop end was cut 1" bringing the length down to 5" as mentioned. I pressed the cutlass in after the cut. I used a traditional 4" long brass/rubber cutlass.
Joe Calcagno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Calcagno Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 9:40pm
Great advice. I'll probably do the same as soon as I get tired of looking for a 6A.
Thank you again,
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 10:03pm
Having the prop shaft look straight is not the same as being straight.
To check you mount the shaft in V blocks and rotate it while checking with a dial indicator to verify straight. Pete can give you exact numbers but I think it has to be within .003 of straight to avoid issues.
Your eye will not see a shaft that has a .015 bend but the V blocks and a dial indiator will find it.
I have a thin cut off blade for my 4" angle grinder. It makes short work cutting through things like the strut you may need to modify. I have cut thick steel with it so a brass strut should be no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Calcagno Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 10:07pm
Thank you, "V" blocks it is.
I'll set it up and measure the runout.
Thanks again,
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 10:53pm
I may have a 6a... give me a few days and I’ll try to put my hands on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Calcagno Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 11:01pm
That sounds interesting. I'm told that my strut is damaged beyond repair, so I will need another.
Let me know as soon as you can.
Thanks,
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2019 at 11:21pm
Pete can give you exact numbers but I think it has to be within .003 of straight to avoid issues..
Joe,
Mark is correct with the .003". But, besides the middle of the shaft, get a reading aft of the strut. It's a common place for shafts to bend. Set the shaft in the V blocks one up around the coupling and the other were the cutlass runs. Then dial the aft end of the taper looking for the max of .003.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Calcagno Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2019 at 1:26am
Great idea, I'll do it.
Thanks,
Joe
zwoobah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2019 at 9:15pm
Joe - was browsing Bring a Trailer today and came across your name. This '62 looks beautiful. Hope you're making good progress with the boat
https://bringatrailer.com/listing/1962-chevrolet-corvette-29/
1968 Mustang 16 - 351W powered
