  New Posts New Posts RSS Feed - Leaking carburetor
Leaking carburetor
 Post Reply Post Reply Page    <12
Slalom fan 4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 1:05pm
Fingers crossed, I prepped with a little sandpaper and acetone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2021 at 1:43pm
Originally posted by Slalom fan 4 Slalom fan 4 wrote:
I have just completed the epoxy job and I am already looking at new holley and normally it would already be ordered but I bought her last year and already. Did trailer bunks, steering cable, throttle and shift cables, and just had new pcm 80a tranny installed after old one started leaking last September so 5k in repairs already way past "BOAT".
Don't worry Rodney, somebody will come along at some point and recommend a Quick Fuel M600 marine carburetor if you're gonna spend the money on a new carburetor.
It'll save you some money if you eventually go the new carburetor route.
Maybe your son in law can get one through Auto Zone too Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2021 at 6:54pm
Someone did mention the m600 and that was a rep at holley. Still waiting on repair its been 30 hours just need to get it to the water unless just turning on key is enough to fire up fuel pump and pressurize the bowl enough to check for leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2021 at 7:09pm
I'm thinking you have a mechanical fuel pump that won't pump unless the engine is running Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slalom fan 4 Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2021 at 10:20pm
Update, the jb weld worked.
