  New Posts New Posts RSS Feed - Stringer Replacement Decisions
 Post Reply Post Reply Page    <123
Tonali_III View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonali_III Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 12:45am
Originally posted by iplan iplan wrote:
I think I'm going to try and get it done by myself.
Anyone got a shopping list for required "tools?"
I would start with a good set of basic mechanic's hand tools . From there, a decent circular saw, cordless drill (Dewalt is very good), ball peen hammer, claw hammer, and a couple different sized pry bars: one about 12 inches and another about 4 feet.
I am personally fond of air driven power tools! I like a good air drill, straight die grinder (which you can put cutoff wheels in), right angle die grinder, 1/2 inch drive impact wrench, 3/8 drive air ratchet, and a good quality DA (Random Orbital) sander. If you can find a good straight sander (18 inch is good), it would not be a waste.
The one thing you don't want to skimp on is a good pair of torque wrenches. I prefer the clicker type, but beam type are good, too. It depends on what you are using them for. I would invest in a 1/4 inch drive and a 1/2 drive. The most important thing about any precision tool is to keep it calibrated. A torque wrench is no good if it isn't accurate.
Harbor Freight Tools Harbor Freight Toolsare okay, but be careful. Some of their tools are Chinese made junk and not worth what little you spend on them. I would never buy any precision tools (torque wrenches, calipers, micrometers, etc.) from Harbor Freight.
It is a decent place, however, to "Window Shop".
1974 Southwind 20
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6752" rel="nofollow">1972 Mustan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonali_III Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 12:47am
Remember, you can usually rent some specialty tools that you don't use frequently, too. O'Reilly Auto Parts has a tool loan program and some Home Depot's have tool rental.
1974 Southwind 20
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 8:32am
Tony,
Didn't you mean to say that all Harbor Freight stuff is Chinese junk? Honestly, I have never seen anything worth buying from them.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 10:14am
[QUOTE=Tonali_III]   1/2 inch drive impact wrench, 3/8 drive air ratchet, and a good quality DA (Random Orbital) sander. If you can find a good straight sander (18 inch is good), it would not be a waste.
QUOTE]
Tony - Do you need all these items on a stringer job? I can't see what you would use use the straight sander, impact wrench, or torque wrench for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonali_III Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 12:28pm
Tony,
Well, a few are okay like engine stands or may be a drift, or punch. But yeah, they're mostly junk. Definitely not up there with "Craftman" even.
1974 Southwind 20
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonali_III Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 12:32pm
QUOTE]
Straight sander would get your hull floor straight for attaching the stringers, but as for the impact and torque wrenches, I was referring to what a reasonably equipped home shop would have. I later pointed out that some of these precision tools are also available for loan or rental at your local "big box" shop or auto parts store.
Like Tim Allen says, "More toolds! More POWER!!!"
1974 Southwind 20
ski-guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ski-guy Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2013 at 12:36pm
Assuming you have all the tools to remove the engine and running gear - the 4" grinder is the workhorse tool for this job. Cut the floor out with a diamond blade - cut the stringers out with the same blade - grind/sand down the floor to accept the new stringers with the flapper sanding discs for the grinder. I was able to 'trace' my stringers as they were in pretty good shape with a router and straight bit. Planed the stringers with mostly a hand plane. I bought a bunch of other 'project tools' like a sawzall, ascillating tool for sanding in corners (barely effective), power plane, but the grinders (I burned one cheap one out) has been key. Used a few clamps and such as well when installing stuff so far. May need a sander as the foam goes in (haven't got there yet) - if you buy them as you need them and don't think too much about it - doesn't hurt as much.
1980 SN - don't worry dear, I may have $10+K into this project boat but I can easily sell it for $5k
2000/2001 Glen-L 'Squirt'
2006 Malibu LSV
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonali_III Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2013 at 2:52pm
On my Southwind, I used a circular saw set to about 1/8" depth and went around about an inch from the hull sides. I then used a garden shovel to dig out the foam in large pieces and then a 12" pry bar to pop it away from the glass hull sides and bottom.
I didn't need to cut out stringers, so I cannot speak to that.
ski-guy's assessment is reasonable though.
1974 Southwind 20
Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nelson Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2013 at 12:07pm
I have read many of the floor/stringer replacement threads because my 86 is going to need it sometime soon but one thing keeps coming to mind. This sounds like it could be a nice little side business for someone on this site who has the knowledge and the time. Seems like someone could make a few bucks here for those of us who dont realy have the space or time to do it ourselves and have no idea who to turn to otherwise.
1986 Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2013 at 12:28pm
IMO, the materials alone can turn the ownership value of an old boat upside down, leaving no room for profit.
Also, these boats are spread out around the globe. Transportation cost, even regionally, would also cut into the economics of a stringer repair business.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2013 at 12:48pm
Nelson,
The same is true for wood boat restoration. Would you be willing to pay around $60 per hour for labor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2013 at 12:59pm
Nelson,
And don't forget to multiply that hourly rate by the approx 200 hrs a stringer job takes. Then add material costs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nelson Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2013 at 1:45pm
Ya. Your right. Guess I was thinking of the person who might be in it because they enjoy working on boats and not for the money. I think I am going to make due with mine the way it is for this season and maybe buy a newer one next year. We will see...
