AmSkier Construction |
Post Reply | Page <123 |
Author | ||
Duane in Indy
search: {4 exhaust tubing stainless} on ebay if you want 4" |
1978 Mustang (modified) |
backfoot100
I got it online from a place called BW Stainless. It was several years ago and a quick search looks like they're no longer in business. I'm pretty sure it was 304. |
Eddie |
backfoot100
Good call Duane. Check this out Pat. Looks like the same stuff that I got. You just pick the diameter and length. It's only money so make sure that your bank account is covered. Burns Stainless |
Eddie |
Pat, Here's one source for SS tubing. They will cut any length you need. This is 303/304 SS. Some have used "muffler" grade 400 series which is cheaper. It will last but not as long as a 300 series. Going all the way to 316 SS is not needed. EDIT: Disregard Duane. He keeps on mixing up his material grades. |
pfelgner
Senior Member Joined: June-22-2010 Location: Toledo, Ohio Status: Offline Points: 168 |
right with at Bank it don't seam very cheap!
88 Martinique BR
87 BFN 2001 |
Duane in Indy
EDIT: Disregard Duane. He keeps on mixing up his material grades. [/QUOTE] You lost me on this one Pete |
