Velvet dip stick |
Post Reply | Page <1 2345> |
Author | ||
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11112 |
He'd look funny down there in his momogrammed long johns Gary |
Gee that looks just like my picture from the other day Probably the only thing that might be needed is a new hose since that fitting looks pretty rusty but with a little time and effort I figure it would work just fine.. |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Yea, I got to replace the "90 fitting" as I messed up the threads. Are those special hoses are will a standard hydraulic hose work_I can have them made here in town?? |
Thanks(1)
A standard hydraulic hose would be JIC 37 degrees so, do take the fitting with you to the hose shop for a match.. |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3749 |
The Hydraulic shop will want to know what pressures and temperatures this hose will be subjected to. I suspect pressures will be less than 300 PSI and temperatures less than 250 degree's F but that is my guess. Maybe one of you have details?
If you don't know your pressures and temp needs they might sell you a hose that is over kill for your application as some hydraulic applications need to handle over 3,000 PSI. |
Duane in Indy
Bear in mind that the trans fluid goes to a cooler that is make of copper (or brass) and it is only capable of lower pressures. Kinda looks like a brass fitting. And it kinda looks like it only sealed up on the end of the angle. That leads me to think that in fact it was two different angles. Maybe enough torque and it seals up? Not the right thing to do but "maybe" it would work?? Don't jump on me to say it wont work, just my guess as to what may have happened. |
1978 Mustang (modified) |
Duane, Good eyes. Yes, to me it does look like they mixed up the 45's and 37's! Now Timmy boy wants me to call PCM and B/W but, who actually installs the trans and cooler? Is the engine marinizer buying the trans, fitting it on the engine and then sending it to the boat manufacturer? Or, is the boat manufacturer buying the engine and trans and combining the two? Considering that the paint matches, I'd be inclined to say it's the marinizer but does anyone know for sure? John, When you get to your hose shop, make sure you ask some questions regarding the 45's vs: the 37's and combining the two at one assembly. |
jterr
For ones that don't understand any of this, like me-
jterr
After going all over town searching for above parts, I did get the 90 degree , but found out I messed up the threads on this
and can't find one with threads all the way through . Suggestions JT |
Thanks(1)
John,
You'll need to purchase a 3/8" pipe tape and make one yourself. With the tap, it's possible you could even clean up the threads on the old one. |
jterr
I thought of that , but can't find a thread fixer... Maybe Harbor Freight |
Look on Ebay for a tap. |
And for a comparison of a JIC 37 degree fitting on the left and a SAE 45 degree fitting on the right here's a picture. You can see the different tapers pretty easily |
And since I had one of each fitting in my hands, I built a little rig and screwed a B/W trans cooler hose onto each fitting and pressurized each fitting to 150 pounds to do a little real life testing.
Neither one leaked, but the 45 degree SAE fitting had about 50 % more sealing area when I checked the seating surfaces with some prussian blue. What's all this mean to me? It means PCM did it right in spite of what Pete might seem to think. Which means the 45 degree SAE fittings are just fine with the original equipment hoses or if for whatever reason you want JIC 37 degree fittings they'll work too with the original hoses. You might keep in mind that you can find all kinds of info saying that the 2 different fittings are incompatible.....................but they both sealed in this situation.. |
Thanks(1)
Maybe the same store you bought the fitting at. Most any hardware store should have the right tap to clean those threads up. And.............if you screw it up you can get that bushing at the link below. It's fairly expensive but tthat's probably because it's threaded on both ends. One end for the external fitting and the other for the return pipe link |
jterr
I'll keep looking around, most everyone has but not big enough.
Thanks JT |
jbear
4 pages of good reading....nuthin' good on the tv so this filled a little time. john |
"Loud pipes save lives"
Ken, Nice test and thanks. Did you use matching 45 and 37 female hose ends or did you use PCM's 45 on each? That's what started the discussion that the female and males have to match hence the concern. BTW, it's really not my concern nor what I think but some group of engineers called SAE International
It was the same hose from a B/W transmisssion cooler with a PCM part number. on it.
Screwed that hose on to each fitting and tested. Both fittings were brand new Used a little prussian blue to see how they were seating and they both seated pretty well but in slightly different spots on the taper. It seems to be your concern that you think PCM or B/W or whoever used mismatched fittings like you said earlier. You really should remove your hoses and fittings that have lasted so many years with no leaks and replace them all with 37 degree JIC fittings and new hoses to go with them just to satisfy yourself. I'll stick with the original stuff. Kinda ironic, me telling "Mr Original" that I'll stick with the original parts. |
Since you used the same hose on both fittings, the test is irrelevant. Is the female fitting on the hose a 45 or a 37? Since you got more contact area on the 45 male fitting, I'd say the hose end was also a 45. Only a back yard hack would mismatch fittings! |
You're the one questioning the hose, you figure it out And explain the irrelevant test while you're at it Let's go back in the thread and see who started saying that the fittings were mismatched from the factory..........somebody named YOU. |
Yes, I started the discussion out of concern of using proper fittings ether 45's or 37's then you continued with your irrelevant "test" using mismatched fittings. What needs to be explained? |
Well, this statement right here might be a good one to explain, since the transmission came with 45 degree SAE fittings and matching hose. Do you remember saying that you never looked at the fittings on your transmission? I guess you just assumed they would use 37 degree JIC fittings without really knowing what you were talking about And the mismatched fittings test was to see what would happen if you screwed the PCM hose on to a JIC fitting. |
Duane in Indy
Who really gives a rats @ss what they are if they don't leak in this low pressure situation??
Is an ACBS judge going to deduct points?? How would they determine what was original and how could they tell the angle?? If they had any common sense then they would not even be concerned. Same as another on here should be --unconcerned. Gosh I hope Spring shows up early this year. |
'Bout time you showed up again Duane
Just trying to keep Pete's bum dope under control. You know how that can be. |
Ken, You are correct that I did not know what fittings were used by PCM. |
Duane, Get over the ACBS issue. They are a great organization that you obviously love to repeatedly slam. Why? What do you really have against them? |
DVskier
Senior Member Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
Other than Pete who really cares what the ACBS thinks? It seems to me like Pete has. Museum and he is the curator. These boats are meant to be used and enjoyed not stored in perpetuaty. When you're putting less than 10 hours per year on a boat it's ridiculous but given the desire to live in the great white north somewhat understandable.
David, There are over 11,000 people that do care about the ACBS. Yes, not too many here on CCfan but there are others like Alan who, like myself appreciate the organization. All of the members boats are not what you may consider show quality and are daily drivers or like myself have both. As an example, I really wouldn't consider placing my Tique in a judged show. That is my daily driver and is used as such. You are correct that, I don't get the hours in on it like some do in the southern states. Have you ever heard of the state with 10,000 lakes? How about the Three Lakes/Eagle River chain I'm on. It happens to be the worlds largest inland chain of lakes. Lots of water for boating!! FYI, there is a ACBS class for boats built up to 1995 and they do not have to be made of wood. |
SNobsessed
It's the CCF reunion's boat show that counts anyway!
