83 New Stringers & Floor |
Post Reply | Page <1 56789> |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10777 |
Thanks for the diagram JT I think the thread in the link will give you some good fuse information link |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
You're welcome and Thanks
JT |
jterr
Update:
Here is the vent collection box repaired and a question, should these exhaust flappers be tighter ?? |
Thanks(1)
Nothing wrong with that flap JT |
jterr
How about some fuel tank sender questions;
Should it be replaced ? Can they be tested? Can I get at auto store? |
Thanks(1)
John,
Yes, the senders can be tested for resistance. I have never seen any difference between an automotive and marine. |
Thanks(1)
John,
You should read close to 33 Ohms full and 240 empty. As you move the float, the reading should be smooth indicating there aren't any dead spots on the resister board. |
Don't bother with those old style float lever styles check into these -
]link |
John,
Yes, if your sender does check bad, and or you want a new one, then the sender Gary linked is by far superior to the old are style. The only down side is the extra cost.
The pdf instructions tell you how to measure length,once that is found you can google price shop,I see them cheaper than their own site on ebay for example. pdf link
jterr
OK I think I'm brain dead. . I'm ordering one of those senders and in the PDF said float needs to be 1' from bottom. I have a 12" tank so I need a 11" sender????
Thanks(1)
12 minus 1 equals just what you're thinking.
I think your brain is just fine. |
jterr
Thanks . Any suggestions on tank cleaning. I looked in it and what I see is just clear water, the covers I put on connectors dry rotted and let a little rain water in..
Thanks(1)
jterr
Have to ask again:
Any suggestions on tank cleaning. I looked in it and what I see is just clear water. |
jterr
A DUHHHH moment--Is there a way to check all my connections (to make sure pump, blower and lights) without motor and battery in boat???
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21141 |
Multimeter with continuity setting will verify point to point connections... of course you’d need a battery to confirm functionality of each accessory.
jterr
Did that before connecting as the wires were all at front of boat,now they are where they should be.
I guess what I was asking is how to connect a power source without motor? |
Take a look at the 8-pin wiring harness schematic. Put some jumpers between the 12v and gnd pins directly to the battery and that will power the dash and any downstream accessories.
JtT
Remember this colorful diagram from the other day. On that plug for the dash #5 is the ground and #7 is the battery supply. Hook some wires from your battery to those .
jterr
I was thinking that -yea right-
Thanks will try later and let you know |
jterr
Worked great, have power.
Thanks |
jterr
Questions,Questions…
Just put rudder back in, are there any specs as to how tight to make the big brass nut? Thanks, JT |
Thanks(1)
Not really but, unlike the prop shaft stuffing box, the rudder box can be pretty tight. It's not rotating at a high speed like the prop shaft is. Tighten it until you get some resistance on turning the rudder. When you get the boat in the water, you'll want to check it again. I normally tighten the rudder until there isn't any water coming in and the rudder is still relatively easy to turn. |
jterr
Was just thinking this reinstall of parts and realized I need to replace the exhaust hoses before replacing gas tank.
Liked to had a CORONARY when I saw prices for this 3" wet hose Can this be bought local or it's a specialty hose?? JT |
Thanks(1)
Marine rated exhaust hose is on the expensive side but, remember, it's below the water line. You really don't want it to fail when the boats in the water. Shop around for the best price. Locally? you may end up paying more?
Go2Marine used to have the best prices but Pete cover your ears, a few years ago when I needed some I went to West marine and found they were very competitive. Ordered to the store,it's with in walking distance to me,and did not have to pay any shipping. I understand they do price matching as well now but don't know what the conditions are. Worth a look if one is near by.
jterr
Ordered hose, now time for carpet.
Has anyone else used the Lowes carpet? I used in the 79, seems a little thin. Thoughts |
jterr
Another question.
Why are my Throttle and shift cable different lengths? Want to order new ones and it looks as a 16' would work for both?? Suggestions; Thoughts didn't work above |
Duane in Indy
Used "BassBoatCarpet.com" on mine. Very pleased. Several thicknesses also. |
1978 Mustang (modified) |
