  New Posts New Posts RSS Feed - many, many thank-you’s
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: many, many thank-you’s
    Posted: May-28-2008 at 12:37pm
just wanted to thank everyone again for all the transmissions im recieving from MIS-ALIGNMENT and all the parts i sold to guy's for a second time..and a labor charge
I am being duragatory and to date am on my 11th fix it again Sam transmission because of minor mistakes made when trying to rebuild at home or at your local trans shop,
Please take out an hour of your time this weekend and check your alignment, it will save you in the long run and the boat will perform that much better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2008 at 1:48pm
Eric, after over 1,000 hours our velvet drive is starting to slip a bit. I know I need to check the alignment soon, but it's always felt real smooth turning the prop by hand, and no vibrations or hard prop strikes in the last 500+ hours we've owned it.
Increasingly probable to slip under the following coniditions:
Cold
Hard acceleration
Tighter the turn at higher the speed
If we can get through this season that'd be great, just put an ACME under the boat and should have the timing figured out real soon too thanks to my CCFan friends Magicman and JoeinNY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2008 at 3:14pm
Hollywood, keep nursing it, its getting up in the hours and there is really nothing you can do to clear up the slippage, it sounds like the alignment is OK, but the true test is with the feeler's....you wont do any further damage by running it with the slippage, but it will get to the point of no return
Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2008 at 3:37pm
Eric, Doesn't HW need to add a can of that additive stuff?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2008 at 3:39pm
Pete, I already put in 2.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2008 at 7:46am
Mine has 1698 hours on the clock...
No slippage as of yet, nor vibrations...
But, alignment has been checked every year, so the PO states.
I checked it this year, thanks to the great thread from Eric.
Hope she will keep up the good work...
- Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2008 at 10:22am
teaspoon of brake fluid should cure it hollywood
RainDog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RainDog Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 11:40am
I think you'll be seeing my BW-71C this winter. I must have warped plates. At idle and in neutral, when I hold the trans flange with my hand, I feel a slight pulsing.
How many scheckles do I need to save up, Eric?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 12:59pm
i got 90 days same as cash, are you sure that was the tranny shaft you were feeling?..
It will be reasonable
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 2:04pm
Steve, he'll even do it twice for free .... Doh'
Sorry Eric, I had to do it... hehe..
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 2:27pm
second times always free
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 2:31pm
I'll put the new kid on it, fresh out of vo-ed, he hit my brothers Cadilac from the front bumper to the rear bumper last week and yesterday he was backing his car up and caught the front bumper of his car on the trailer hitch and ripped it right off.
trans man in the making
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 2:32pm
i got that shaft you were feeling..
eric, you gonna be in the shop July 9? 2 free HJs is usually a deal I don't pass up. I'll even give you a choice on which color wig to wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 3:28pm
im not big on recieving,im a giver not a take lol i should be here on the 9th, you'll be in town? I'll plan a lunch and possibly some refreshments
Post Options Post Options   Thanks (0) Thanks(0)   Quote RainDog Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 3:28pm
<groan>
I knew as I wrote the question that I was setting myself for some misquoteables. I even intentionally avoided the word 'shaft', to no avail...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 3:31pm
Actually I just planned on swinging through the parking lot and side swiping your truck. Maybe I'll come inside though to use the restroom. I won't be around until ~2:30 p.m.
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 4:29pm
Originally posted by RainDog RainDog wrote:
<groan>
Steve, yeah, you gotta try and choose words carefully around here...some of the "young-uns" still get their school kid kicks that way..
64 American Skier
62 Classic..
73 Ski Nautique
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 10:19pm
Eric now that temperature has severly lowered down here my transmission started again doing the neutral turning like crazy thing again. It wasnt that severe on summer, is there anything I can add to the fluid? I'm using Allyson C4. Should I switch to Dextron III???
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2008 at 11:58pm
Speaking of thank you's, Thank you again Eric for the shaft and coupler work, finally got time today to put it back on, heated the coupler in the oven at 400 for one hour, it slid one about 90 percent of the way required just a couple of love taps to get it seated, quick check with the feeler gauges, tightened everything up, prop again spins smoothly with one finger! Time to get the fluids changed and drop it in the water!
Did you find your correct craft yet?
Gary
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 1:15am
Originally posted by 65 'cuda 65 'cuda wrote:
Speaking of thank you's, Thank you again Eric for the shaft work.
Gary
You know RainDog...sometimes we just can't help ourselves on here.....
Two many good opurtunites.
john
"Loud pipes save lives"
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 9:55am
Luch, the allison oil might be giving you the drag, most times they want c4 in the trans for diesel applications because of the lower RPms., doing a switch over would require pulling the trans and dis-assembling because on a Borg it is close to impossible to get the oil out of the front cover cavity. the 2 oils may be compatable so if you switch dilute the old oil at op temp and pump out and repeat a couple more times. I think your drag will clear up with Dexron in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 9:56am
thanks for the hops Gary
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 10:10am
I found that my alignment changed about .006 between checking it on the trailer to checking it floating. I re-adjusted it to be aligned as floating.
FYI - Might be a false sense of security if you only check it on the trailer. Or Eric could just take on another trainee . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 10:29am
I got enough trainee's they like to hit cars in the parking lot, i could use some tranny's though, I had too snob lol
again on the alignment, its these things that will make the boat and running gear last 20 or so years and its nice to hear that you took out the time to do the alignment truly the correct way. a commendation goes to you Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 6:27pm
I'm still not understanding how you can do an alignment in the water. Don't you have to slide the hose up off the log?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 7:00pm
HW, no, just take the 4 bolts that hold the coupling together off and then check at the 3,6,9,12 o'clock position, it should be .003 or less all the way around the coupling
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 7:58pm
That would make it more exciting!
1988 BFN-sold
