  New Posts New Posts RSS Feed - No Reverse!!!
No Reverse!!!
92NautiqueSNOB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 92NautiqueSNOB Quote  Post ReplyReply Direct Link To This Post Topic: No Reverse!!!
    Posted: June-23-2008 at 12:01pm
Having a problem with 1992 SNOB transmission. Forward gear running strong- no issues, reverse will not engage. Tranny not running hot, fluid level good- clean. Cooler lines etc all good- pressure good no leaks. No squeaks, squeals, knocks. Originally thought must be linkage, but gear lever on tranny is getting back all the way. WhEn placing in reverse, it seems as if the reverse clutch not engaging at all- simply revs as if in neutral. It is a PCM Power Plus 1.23:1 gear-
ANY SUGGESTIONS? AM I LOOKING AT A COMPLETE REBUILD?
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2008 at 2:34pm
How can i say this, 750.00 to fix the problem. anywhere else you'll wind up ordering 800.00 in parts then the labor
call if you like 877-369-6693
Post Options Post Options   Thanks (0) Thanks(0)   Quote 92NautiqueSNOB Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2008 at 1:20am
Thanks, Eric- you were very helpful on the phone this morning- I still need to get the boat back- also had a new crate tranny put in my Tahoe- lost 2 transmissions in ONE weekend-
I will call you back once I have decided what to do.
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2008 at 2:27am
Wow...nice weekend huh?
john
"Loud pipes save lives"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 92NautiqueSNOB Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2008 at 5:20pm
Great weekend! Fortunately, it only took my old body a couple days to recoup after several barefoot, slalom, wakeboard, kneeboard runs- its gonna take my wallet alot longer!!
hasbeenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2008 at 11:39am
Sorry,I just can't resist..... YOU DON'T NEED NO STINKIN" REVERSE
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2008 at 12:45pm
92, send that 4L60E along, you'll get the package deal
