  New Posts New Posts RSS Feed - 76 mustang runs great then quits
zmom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zmom Quote  Post ReplyReply Direct Link To This Post Topic: 76 mustang runs great then quits
    Posted: July-27-2008 at 8:50pm
Just got the 76 in the water again after new belts, thermostat,water pump, oil change etc. Ran great for about 25-30 minutes then all of a sudden it bogs down and quits. It did this over and over again last summer and could never find what the problem was....It will start right up after sitting for about 10 minutes. Thermostat reads 160....Need help and someone who may have had similar problems.
Thanks
pat
zmom
k.o. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote k.o. Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 3:28am
did you rebuilt the carb?? it sounds to me like the same symptom that we got on our 86.. carbs flooding. when it does that take the flame arestor of and take a peek in the carb and see if it dripping or pouring (it shouldn't be dowing any of those)
tapenick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tapenick Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 4:03am
Flooding or starving... can drop a line in a can from your fuel pump to eliminate supply issues.
Tom
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 12:24pm
Check to see if the timing is set too high.
Tim D
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 12:30pm
Sounds to me like fuel starvation from tank outlet sceeen, check valve, or vent clogged.
River Rat to Mole
Busted Knuckle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Busted Knuckle Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2008 at 12:34pm
so does it run fine @ any speed for 15-20 minutes
then dies because it won't idle
or requires throttle to maintain 1000 + rpm
to keep it running
or does it die @ any speed after 15 -20 minutes
it starts and runs fine aftr 10 minutes @ any speed and then symptom repeats itself?.........
BKG
Volante Barefoot Skier built by American Skier Boats -
www.footngear.com
