  New Posts New Posts RSS Feed - RWP hole
RWP hole
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Topic: RWP hole
    Posted: October-23-2008 at 2:07am
Any thoughts on this? Finally put the Skylark up for hibernation 10-22-08.Was 49 degrees this morn! I'd never make it up north! Upon tearing down my RWP, a Sherwood, I found a hole, about 3/16" deep! Any concerns you think? It's on the front side, the pulley side
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2008 at 2:13am
That's weird. I would have it brazed/welded whateever they do to brass. Are you going to change the seal kit?
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2008 at 2:44am
Nothing's leaking. What do you think? Do they still make a rebuild kit for this style? 6/21/1965 Build date.Or would it just be a take apart and take to our local bearings seal shop,Shawn Products I think. Although we could probally get one, I work for CarQuest.The bushing is cracked on my backplate too but I think it's OK. I've only changed the impeller 2 times since 1970! the first time was in the late 80's when the first one came apart.The 2nd one was 2006.It only had 2 vanes missing. Yes I have been finding pieces every now and then in exhaust drains ,end caps,etc.
66 Skylark
93 SN
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2008 at 3:22am
depco pumps will have the parts for it, as for the hole a little silfos will close that up, or for that matter probably a little epoxy stick
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Brady View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brady Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2008 at 9:40am
It looks like a small casting flaw, if it doesn't leak, I'd leave it alone. If it does leak I would either soft solder of epoxy it. All parts for Sherwood pumps should still be available.
Charlie
Three Lakes, Wisconsin
69 Barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2008 at 7:12pm
You can still get the seal kit.
the bearing is nothing special, just standard size, it's actually the same as a throw out bearing for a car, you can get it at napa.
The graphite bushing is availible too.
http://www.reddenmarine.com/site/new-categories.cfm?counter=1&brand=0&action=Search&letter=0&department=0&category=0&subcategory=0&text=sherwood
Tim D
