  New Posts New Posts RSS Feed - Brass Bypass Fitting
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Topic: Brass Bypass Fitting
    Posted: March-06-2005 at 10:27pm
Does anyone know where to get the 90 Deg. ell brass bypass fitting for SB Fords? It screws into the intake manifold right behind the thermostat. The thread size is 3/8" (pipe) and the water hose size is 5/8". Auto parts stores don't seem to have this. Is it a Ford item? A pic is attached.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 4:06pm
I think this is where the heater hose hooks up on autos.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 4:43pm
I think it is too Tim. I just can't find this fitting anywhere. Mine is corroded away. This is a pic off Ebay - (I lost the bid).
woodyelc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodyelc Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 4:46pm
art and i looked at this and we feel that you do not need the pipe on the ell. chech inside the intake manifold and see if the tube went into something inside. you could also make what you are looking for by using the ell and soldering a piece of pipe into it. hope this has helped. WOODY
woodyelc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 5:18pm
Thanks Woody. Now all I have to do is find one (With or without the tube.). -jim
882001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 6:18pm
jim try kemah hardware they cary alot of fittings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 7:54pm
Kemah hardware didn't have but Craig at Standard Auto found it in an old catalog. I have two on order. The pipe extension is important. It holds a flow restrictor according to the catalog. There are four of these in a warehouse in Houston - I ordered two.
For hard to find auto parts I now have to recommend these guys... Standard Auto, Dickinson Texas, (281) 337-2267, ask for Craig.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2005 at 11:45pm
standard was a lifesaver on my last hobbie, 75 landcruiser w/ chevy 350. the one in webster is also helpful.
