  New Posts New Posts RSS Feed - boom
boom
rleinen79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rleinen79 Quote  Post ReplyReply Direct Link To This Post Topic: boom
    Posted: March-11-2005 at 10:47pm
I recently got a good deal on a boom for my 97 SNOB........however, it has the contour in it instead of being straight. Does anyone else have one, or think it will be a problem having it? I only ask because in Overtons it says the countour is designed for Master Craft, Malibu, Moomba, etc, but the straight boom is listed for Nautiques. Will it still work? Any experience (or just opinion) would be appreciated. Thanks!
Tribal150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tribal150 Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2005 at 2:19am
Generally you would use a straight boom if your engine box wraps around the side of the pylon, the straight boom mounts higher on the pylon negating that problem, so if you have about 3 inches clearance around the pylon roughly 10 inches from the floor there should be no issue with using a curved boom.
