Removing the Eye from the Pylon |
Tickfaw1979
Newbie Joined: April-06-2009 Location: United States Status: Offline Points: 1 |
Posted: April-06-2009 at 12:23pm |
I need to remove the eye, the attachment point for the rope, from the pylon in order to install a Big Air Pylon on my 1979 Ski Nautique. The new pylon is to slip over the existing one mounted in the boat. The eye is connected by pins or set screws, I really connot tell. Can anyone help me with a method to remove the eye? I don't want to force it and break something. Thanks
Tickfaw1979
BuffaloBFN
I would say to check out the super delux boom mount at the bottom of the orange stripe.
Mine had 2 of what I think are called roll pins. They take a special punch to drive them out. I did this and was able to move it side to side a tiny bit but no more. So off I went to let the machine shop break it. |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
They are very hard to remove. I broke mine. A friend of mine broke his. I suggest you get the item that sells in the CCFan store. It bolts onto your existing pylon and has a pole that you can apply your Big Air Pylon.
83Ski
WakeSlayer
Don't wreck a really nice pylon. From what I understand they are fairly uncommon and therefore, valuable.
Get the clamp. |
Mike N
1968 Mustang |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
Remove the ring and finger?? EEK!
Hey! their was a member looking for one why not trade him before it gets screwed up? |
37N122W
Groupie Joined: December-15-2008 Location: United States Status: Offline Points: 83 |
Interesting, mine pulls right out. The guy I bought it from must have punched out the pins. Can I get them somewhere and re-install them or should I just slide a bolt through? It doesn't seem save to pull someone with it when it could pop right out. That'd leave a mark...
JJ |
"It never gets easier, you just go faster." Greg LeMond
78nautique78
Groupie Joined: November-10-2007 Location: United States Status: Offline Points: 51 |
I removed mine with success. I Removed the pins in the post, soaked it in penetrating oil and used an engine hoist connected to the ring to put tension on it. don't put so much tension on it to lift the boat, because you can. but enough to make it good and tight. you can wait a couple days and it will come out on its own, by increasing the tension on the hoist over a period of time or with the hoist on it you can use a long bar to turn it. once you turn it just keep tension on it and it will lift out. A little heat from a torch won't hurt it either. all you need is a punch to get the pins out no special tool required. just be careful with the bar if you go that route. small turns at a time. I was thinking about the clamp on pylon, but It seemed to big and would get in the way in these smaller boats. that's just me though.
Cheap beer, Trailer parks and Correct Craft. "Life is good".
79TiqueRebuild
Senior Member Joined: January-21-2009 Location: Kansas City, Mo Status: Offline Points: 238 |
If you want to sell it let me know somebody took a hacksaw to mine.
I removed the old piece using lots of penetrating oil and working it back and forth a little at a time. The hardest part of the roll pins was finding the right punch to drive them out. |
