  New Posts New Posts RSS Feed - Eric, Velvet drive??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Eric, Velvet drive??
    Posted: April-28-2009 at 2:11pm
Eric,
What's the difference between a model 70 and 71? I looked in my B/W manual and could only see a different quantity of clutch plates. Is there a engine size difference they can handle?Steve (62wood) is worried that his 70 won't do the job in his Higgins. Certainly better than a Dearbo though!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2009 at 10:15am
Eric,
No comments??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2009 at 10:38am
Pete, I've asked the same question. We've got a 70 and a bell housing for the 312. They were probably made before Eric's time and don't break, so he's never seen one.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2009 at 12:04pm
some of the 70 series had a 10 spline input shaft and a older style pump, single reverse plate, forward is basically the same circuit as of later styles,different breathers, different dipsticks. as with time they evolved and truly the best trans for these boats are the current 10-17-003 and 004 models if you search for one. Riley Pleasssssseee, BTW, I do keep a couple of them around so dont worry about parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2009 at 12:29pm
So Eric, what about a model 70 hooked up to 327 Graymarine 180 HP? Will it handle it?
Or a 312 (Bruce's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2009 at 12:28am
yes it will, if its fresh
