  New Posts New Posts RSS Feed - Fuel Pump not priming
Superk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Superk Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Pump not priming
    Posted: March-18-2005 at 10:41pm
I have a '99 Sport Nautique with the GT40 engine. My fuel pump does not always prime when I turn the key (which means the engine won't turn over due to no fuel). I found that if I "fiddle" with the fuel pump sending unit (not sure exactly what it is called, but is a small black "box" mounted on the rear portion of the engine by the fuses) the pump will prime. Does lead to a bad unit, or simply some loose wires or dirty connections?
thanks,
Kent
nms1991 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nms1991 Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2005 at 5:46pm
You may have to take your boat in unless you have a good understanding of the Ford EFI system.
Siveck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Siveck Quote  Post ReplyReply Direct Link To This Post Posted: March-22-2005 at 9:33pm
If that small black box is a fuel pump relay, then it should be easy and cheap to replace. Also check for loose or dirty wires at that connection.
