STUCK THERMOSTAT COVER |
SkiLew
Groupie Joined: May-20-2004 Location: United States Status: Offline Points: 73 |
Posted: March-21-2005 at 10:52am |
Engine acts as though the thermostat is stuck open. Will not get over 120 degrees F so I decided to replace it.
Tried to replace thermostat this weekend, removed the two cover bolts but the cover acts as though it were welded on. It will not budge. I did not want to be too aggressive and crack the cover. Any suggestions? |
Bill336
Senior Member Joined: October-12-2004 Location: United States Status: Offline Points: 106 |
I've used a sharp wood chisel to cut into the gasket and pry the housing off. Be careful to keep it level and use small taps with a hammer so it doesn't gouge either side.
jameski
Senior Member Joined: May-18-2004 Location: United States Status: Offline Points: 368 |
I do the same thing, but I use a putty knife. The blade is thinner... and cheaper to replace when you tear it up
Tim D
Use something thin, even a razor blade. Try spraying the outside with gasket remover.
Tim D
Jim_In_Houston
I always just knock the crud out of mine with a big hammer. It works. Be sure you have the bolts out first.
Tim D
I hope you use a rubber mallet or a dead blow hammer.
Tim D
