  New Posts New Posts RSS Feed - Running in gear out of water??
Wheeler Dealer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Topic: Running in gear out of water??
    Posted: June-27-2009 at 8:22pm
I am cleaning up my 89 SN and was wondering if it is a good thing to try to put the boat in gear while it is on the trailer and not in the water? What potential damage could this cause?
Thanks for your input.
John
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2009 at 9:28pm
You need to run a hose on the strut bushing while it is running .You also need to be carefull of shaft packing
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2009 at 9:32pm
Patrick, So in other words don't do it.
Thanks for the info. I will have it in the water Wednesday.
Nice Looking Skier!
John
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2009 at 11:48pm
John,
I had a friend spray his cutless bearing with cooking oil for a short dry-test, but I'm with Pat. Don't do it.
BTW, What are you cleaning that you want to put it in gear?
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 3:57pm
I just bought this boat and have been working on tuneing it up. I was just wanting to make sure the shaft turned straight. Looks good but wanted to see the shaft spin. I will test in water this week.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 5:39pm
John
Your visually looking for shaft run out really isn't the best method unless your eyes are better than mine!!! A dial indicator clamped to the strut will tell the truth. You will want to check in the middle of the shaft which will tell you straightness from the strut forward and then on the tail end of the prop taper telling you if the shaft is bent from the strut aft. I'd say anything over .005" is the point to be concerned.
Have you done a engine/prop shaft/strut alignment? It too will tell you if the shaft is bent forward of the strut but not the primary reason. The tail end of the trans can be blown out with bad alignment. Eric did a pictorial thread on how to do the check if you're not familiar with it. I'll do a search and find it for a link for you just in case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 5:42pm
Pete,
Thanks again for your help! I will check out that thread.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 5:54pm
John,
I'm just getting used to the new search feature so it took me awhile to find it but here it is: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=6037&KW=shaft+alignment&PID=58708&title=span-classhighlightalignment-span#58708
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 6:01pm
I like to make a run with the back deck out after any major work I've done. It can be worth a 1000 words.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 6:02pm
It's giving me fits Pete!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 6:30pm
What is? Still have the vibration? You did check the shaft correct? All RPM's? It may be normal as some hulls seem to develop harmonics more that others. That "battle ship" stringer system you put in just isn't going to absorb any vibrations!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 6:53pm
You're funny! And right! It makes a nice crisp sound ripping down the lake...hard to describe the difference between now and then. The wine glass is still on the dash.
I meant the search feature is not what I'm used to.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 8:54pm
Thanks John . Right I would not suggest running it out of water . You could burn some important parts . Bring it to Green Lake . We will take a look at it .
Pat
My 72 Skier
Rock River
Dixon,ILL.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 8:59pm
Mine likes to freewheel a little in nuetral till it warms up on the trailer, I always hose down the cutless bearing before connecting the engine flusher and it seems to do the trick, but I do not put it in gear. Experience says it could work briefly??????
1987 Ski Nautique
pwningjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pwningjr Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2009 at 2:06am
I'd venture a guess that the low rpm's of a dirty neutral are way lower than even idle.
Jay
"Proud to be a geek"
Big Heavy (stephan): One can't always be perfect when water dancing on your shred stick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2009 at 4:40am
Your probably right,like I said I never put it in gear,just theory that a supply of hose water might support it for a brief run. I know the first time I ran it on the engine flusher it let out a squeel. I immediatly shut it down till I figured out the source. Since, I always wet it before I hook up the flusher and it has remained silent. I believe this has saved my cutlass bearing during its nuetral freewheeling.Thank goodness I am finally at a point where I can run it in a lake. Since I don't really know I should probably keep my nose out of it, but how else would I learn terms like "dirty Idle"
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wheeler Dealer Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2009 at 11:26am
Thanks again for the info. Now the question is...when I put her in the water this week, how will I know if the cutlas bearing is bad or good? It sounds like it is not a good idea to run the motor with a water hose hook up either or is this not correct? Yes, I am a newbie.. She had been sitting in a barn for many years before I brought her home.
Thanks for the help.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2009 at 11:44am
John
John,
Check for radial play between the prop shaft and the cutlass. If the alignment is good and the cutlass good then there will be very little to no play. If it's somthing around .020" then it's time for a new cutlass.
Did you check your alignmentyet? This is important! It's been in the barn all these years and should be done before it goes in the water. Then again after some water use.
