  New Posts New Posts RSS Feed - AWhite70
AWhite70
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: AWhite70
    Posted: April-11-2005 at 4:46pm
If I remember correctly didn't you install an HEI distributor when you did your overhaul last year on 351W?
If so did they give you a print out of advance to RPM for the way they curved the dist. advance. I was looking into curving my mallory unit and would like to use that as a guide. Our cam's and engine mod's are very simular and that would give me a good baseline to start from. Thanks's in advance for your help.
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2005 at 10:32pm
Yes I did install an HEI distributor for my rebuild but they didn't give me any kind of documentation on what the advance curve is.
On the bottom of the distributor they engraved 24 deg. @ 3000. So I assume that is the point where it reaches full advance. Aside from that I don't know much other than it works great and pulls hard.
I just got the boat in the water this weekend after the re-rebuild for the proper cam grind and proper piston to bore clearance and she's running strong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2005 at 11:06am
Thanks for the reply. Glad to hear she's back in the water.
