Lubricating steering cables |
David F
Posted: April-13-2005 at 1:03pm |
I want to try lubricating rather than replacing my steering cable on my '93 SN. Has anyone successfully accomplished this task?
I really do not know the condition of the cable, but the boat was partially submerged before I purchased the boat and I am concerned that water entered the cable and started corrossion. The steering wheel was off the boat and not included when I purchased it and I remember the hub fairly stiff when trying to turn by hand. So, I am going to pull the cable and see what can be done. Suggestions welcome knowing that I am nickle and dimeing (sp) myself to death on this project and saving $200.00 would be nice. |
Bhedbloom
Senior Member Joined: December-01-2004 Location: United States Status: Offline Points: 116 |
David,
I have replaced several steering, and throttle cables in older Correct Crafts. I am a nickle and dimer too so I understand from which direction you come, but I think you would be better off to go ahead and get a new one that has the correct lubricant. For no other reason than safety. Happy Boating! |
Barry, South Carolina
David F
Yes, you are probably right. Last night, I grabbed the tiller end of the cable and was able to pull on the rod with great resistance. The steering rack/pinon still connected. After I pushed and pulled on the rod just a few times, it loosened up significantly and was rather easy to move. I think I am going to leave it as is and see how smoothly it operates when the boat is reassembled.
So, for future knowledge, what is the conventional method of removal for the steering cable? I assume one would remove the support tube (tiller end) and pull the cable out from the helm. Does this sound correct. |
skyhawkflyer
Senior Member Joined: February-08-2005 Location: Zimbabwe Status: Offline Points: 275 |
If it loosened up that's good. Maybe you'll squeak by this season. Most likely it'll be far worse next spring after layup. Corrosion only gets worse, it doesn't stop.
tdkosta
Guest |
I wouldn't remove the tube without first marking the position it is bolted on. Normally it is unnecessary to remove the tube unless you need to clean the inside of it. Just unbolt the cable from the rudder arm, and the cable from the tube.
Darrel
Senior Member Joined: June-16-2004 Location: United States Status: Offline Points: 340 |
David Dont pull out the old one before attatching a new one to pull thru at the same time. Thru to the helm is the correct direction. I did it on the 93 SN once, and will be doing it again this weekend on the 95sn.
john33617
Senior Member Joined: July-07-2004 Status: Offline Points: 182 |
drill a very small hole in the outer cover , use a grease gun for a chainsaw bar , very small point , you can pump the cable full , seal hole with tape , works best in the middle , lite grease works best
David F
Darrel:
Great advice! Thanks. John: Interesting idea, but scares me a bit. I might try it if I decide the cable definately needs to be replaced. |
