  New Posts New Posts RSS Feed - Help with electrical problem
jjtaub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjtaub Quote  Post ReplyReply Direct Link To This Post Topic: Help with electrical problem
    Posted: July-28-2009 at 11:37am
I just did a rebuild on my 78 nautique and I have an odd electrical problem and I am wondering if I hooked electrical connection wrong.
So engine starts and seems to run well. The Amp meter does what you would expect and the tach works as expected.
So here is the hitch.
The oil gauge, the temp gauge read obserdly high as soon as the ignition is on (engine off.) Same deal if the engine is runnng. When the ignition is off the gauges read 0.
If I remove the wire from the sender(s)the gauges go back to 0( ignition 0.
The fuel gauge is reading very low, but to be frank there is only 5 gallons in the tanks and that might just be normal.
I was wondering if I hooked something wrong (ignition or altnerator?) that is causing the cuurent flow to be high.
I ordered a new oil sender and it should arrive tomorrow, but my sense is this is not two buggered senders.
JJTaub
78 Ski Nautique-past
94 Ski Nautique
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 11:41am
Are those 2 senders automotive by chance?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjtaub Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 11:55am
DOH,
Looks like I missed one of the grounds to the engine. Touch it to the block and all is well.
JJTaub
94 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjtaub Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 11:56am
Nope both senders are marine.. I am pretty careful to stay with marine parts.
JJTaub
94 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 12:01pm
Smart man!
1988 BFN-sold
