  New Posts New Posts RSS Feed - 1980 Barefoot bung location
Brad_K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad_K Quote  Post ReplyReply Direct Link To This Post Topic: 1980 Barefoot bung location
    Posted: April-18-2005 at 12:47pm
Does anyone know where the bung might be on a 1980 Barefoot Nautique? There is not one under the swim platform where I expected it to be and can’t find one anywhere, I assume it does have one.
Any help much appreciated.
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 1:03pm
On my '78 the drain is in the center of the bilge in front of the engine and behind the pylon. Does this answer your question?
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad_K Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 1:18pm
I did see something there and I gave it a tug but as this is my first boat I was unsure weather it screws in or just pushes in and didn’t want to force it and break it, also where does it drain out from? The prop shaft maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 6:20pm
It probably has a bronze tee-handle screw-in plug, and it drains right out the bung thru the center of the keel.
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad_K Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 6:34pm
Thanks guys, i found it and twisted out no problem.
nates78ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2005 at 7:44pm
The item you were looking for is a garboard plug or to laymen a bilge drain plug. A bung is a plug used to plug a hole in a wooden plank or a barrel.
Nathan
My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad_K Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2005 at 6:49am
Thanks
gordonw View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonw Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 3:33am
Thanks! I always thought a bung was my #!%&*
