Will my gelcoat shine again? |
Tate
Senior Member Joined: October-08-2004 Location: United States Status: Offline Points: 134 |
Posted: April-22-2005 at 5:27pm |
Pulled the stepping pads of of my boat today to buff with oxidation remover. What a difference. The gelcoat under them was perfect after I washed the dirt off. It looked brand new. I didn't know that my gelcoat was all that rough until I saw it. Is there a way to ever achieve this new shine again? I've got Meguire's HD oxidation remover and it's doing a fair job but the shine remains hidden. On a side note; will muratic acid dissolve my decals? Any help would really be appreciated. Thanks, Tate.
Tate
gordonw
Guest |
No solvents bro. Get a rotary buffer or borrow one if you have access to one. Start with a Meguires wool w7000 pad and some dimond cut compound or the heavy you have. I use the dimond cut. This is a clay based product that will start out very course them break down to a finer and finer as yu buff. Use at recomended rpms. This will give you the deep luster that you need. Then go over it with a medium polish and a foam pad to smooth out all the swirl marks. Then....wax the hell out of it! Run painters tape over the decals so not to burn them or just go really light. New decals are also really cheap. I think you can replace the stripes and the rear flags for $400. You got a new boat. Three stage buff. Don't just wax over that stuff. A clean start is the key to a deep shine. good luck.
Jeff
Guest |
I used a product called poli-glow on my 76 century see some before and after pics here. http://www.pbase.com/jhlewis/boat If your boat can be buffed out go for it. But if its beyond repair or you are just lazy like me try poli-glow. No more waxing ever just a maintence coat once a year. The whole kit cost me $52 I only used 1/2 of it for the whole boat.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3365 |
Thick Wool Pad w/ 3m Super duty compund, then good quality fine cut cleaner after washing the pad and boat, then wax.
Heavy ox desires a var speed sander/grinder, not those silly buffers. |
River Rat to Mole |
Dallas
Groupie Joined: February-08-2005 Location: United States Status: Offline Points: 46 |
Porter Cable orbital sander is the king of shine for the neopro detailer. Here is a link to detailing tips and techniques. I use 3M perfectit II then 3M Glaze. The pad you use realy plays a huge factor into how much cutting the product does. Polish will make the finish dull as it removes scratches and oxidation, the glaze brings back the Shine. Post a question to this site for some high quality feed back; I am sure there are some boat owners subscribing to it.
http://forums.roadfly.org/forums/detailing/ I hope this helps. Dallas Neo Pro Detailers site |
gordonw
Guest |
yes! cut with the wool then use the polishing compounds. Grinders, Sanders? Are we refinishing or polishing? Wool, foam, wax. 3M glazes are waterbased right? Does that mean that they wash off? TEFLON is the final stage for me. Grime washes right off. It's non-stick.
GottaSki
Well, yes, a sander/grinder..for heavy jobs.
But I concur; a boat that was always well maintained may never need that power. Mine is a Milwaukee var speed. This 23 year old boat had an abused chalk-white hull and serious decal-shadows. The gloss is better than the pic indicates But Beware, its not a CC.. |
River Rat to Mole |
raygunclan
Groupie Joined: March-21-2005 Location: United States Status: Offline Points: 57 |
you guys should check out
http://www.pbase.com/jhlewis/boat that's the link that jeff (from above) posted of his boat that he used poli glow on! holy crap! if all he did was apply it, where do i sign up????? |
who needs a mortgage when you have a boat!?!?
66altyllskier
Newbie Joined: July-05-2005 Location: United States Status: Offline Points: 10 |
Looks great Jeff! We have a very oxodized 66 Al tyll skier and have tried almost everything. I think I will give the poly-glow a shot before having to shell out for a new gelcoat.
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
call FIBRE GLAST developments corporation.
1-800-821-3283. order 1lb step one mold polish #01102-A and one lb of the step two polish #01103-A you wont beleave it till you see it work on nasty gelcoat. they shipped me both cans for $37.85. it's just as easy as waxing your truck[twice]when you complete step two,just finish with your favorite wax.i used meguires. and because i'm lazy i spent $ 200+ for a milwaukee buffer,but you can do it by hand and get good results |
kenny g
80nauts
Groupie Joined: March-19-2005 Location: United States Status: Offline Points: 93 |
Dude this is what I did and I can't Believe the difference.
1) bought this buffer for $25 http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=46507 2) Used your 3M HD ox remover to remove my old lettering. 3) Used 3M fine cut to buff the whole boat. 4) Used 3M Glaze to protect your gel coat and shine like crazy. Amazing results. I should probrably put some wax ontop of the glaze, but havn't yet. I swear my boat was stored in Hell for the past 10 years and would have never thought it would look this good. Just remember that old CC's supposedly have thick Gel Coat; I think they can always come back to life. Last Advice to give is to use the buffer correctly. I have seen another CC in which the beffer was used more on an angle rather than flat on the boat surface and now it has a lot of divits in the coat. |
SkiLew
Groupie Joined: May-20-2004 Location: United States Status: Offline Points: 73 |
Hey, has anyone tried to wet sand their boat first if the oxidation is heavy? I have heard that this works well for boats that are heavily oxidized.
GottaSki
Yes,
I used wet sanding to cut heavy oxidation and level and remove the ghost image of old lettering. Glass exposed to sun and some neglect, and glass covered by vinyl can get the same compound treatment and wax, and look the same at first, but the glass that saw exposure for 20 years will oxidize at a faster rate and look crummy quicker than the newly exposed stuff, making the old image reappear. I summize the UV damage goes deeper than the surface, and hastens the future oxidation, sometimes requiring heavy-cut compound every year. My experience is wet sanding heavy oxidation before compounding produces a longer-lasting finish, that can be maintained with less work (yearly buffer-waxing and ocassional light-cut cleaner then wax every-other year.) Without the initial wet-sanding, compounding/wax was a yearly job. |
River Rat to Mole |
66altyllskier
Wow, ordered my poly-glow almost a month ago and I'd love to tell you how great it is...but I don't have it yet :-(
The company I ordered it from still shows my order as processing. Guess I'll be polishing this winter :-) oh well... |
woodboy
Groupie Joined: February-11-2006 Status: Offline Points: 53 |
This may have been already stated but where do you order polyglow?
Lake Livin' Rocks
jhlewis10
Newbie Joined: November-17-2004 Location: United States Status: Offline Points: 8 |
Here you go http://www.myboatstore.com/
BrentAL
Newbie Joined: August-03-2006 Location: United States Status: Offline Points: 13 |
[QUOTE=66altyllskier] Wow, ordered my poly-glow almost a month ago and I'd love to tell you how great it is...but I don't have it yet :-(
Did you ever get your order? How did Poli Glow work? Brent |
96 sn 196
66altyllskier
I ordered from FIBRE GLAST, I did get it after a couple months and a phone call, must have been out of stock. Ended up doing motor work this year (and a kitchen remodel) so never got around to it, but plan on using it soon, will post when I do.
