Converting an automotive carb to a marine carb |
Post Reply
| Author | |
Lightfoot
Quote Reply
Topic: Converting an automotive carb to a marine carbPosted: September-01-2009 at 10:32pm |
I am looking at replacing my carb because its been giving me nothing but problems even rebuilt. The lowest price I could find on a marine 4160 holley was over 450. I have a chance to get a new automotive 4160 for free, and I was wondering if it would be possible to get the parts and build a marine carb. If I was to do this, what all would have to change? Ill get a marine carb kit, and some J tubes, but what will I have to do internally? My holley book mentioned a few of the differences, but i couldnt find any real details. Thank you
Lightfoot |
GottaSki
Joined: April-21-2005 Location: NE CT Status: Offline Points: 3399 |
Quote Reply
Posted: September-01-2009 at 11:05pm |
Sorry, The PVCO's in the metering block are going to be sized wrong, and the throttle shafts won't be o-ringed.
Best do it right, do it once. |
River Rat to Mole |
mrhemi
Joined: September-02-2009 Location: Canada Status: Offline Points: 31 |
Quote Reply
Posted: September-02-2009 at 12:26pm |
Since this is my first post on the forum I hope this helps someone. Check with Summit Racing, www.summitracing.com, they stock the marine carbs for less than that. Also they stock Eldebrock marine carbs (re-popped Carters) for less than the Holleys but some mods to your linkage and fuel lines may be required to go that route.
Mr. Mike. |
You know you are getting to be vintage when someone says "Back in the day..." and you can dispute their facts.
Mr. Mike. |
bill1
Joined: May-27-2007 Location: United States Status: Offline Points: 151 |
Quote Reply
Posted: September-02-2009 at 6:33pm |
lightfoot, what problems are you having with your carb? i'm not much help, but someone here may can lead you in the right direction.
bill
Lightfoot
Quote Reply
Posted: September-02-2009 at 7:44pm |
Alright, thanks for the heads up on the differences.
My boat was run in salt water, and really was not well cared for. I have been through everything on it, stripped it down completely and started over, rebuilt the engine, and cleaned it all up. I just cant seem to work out all the little problems. I rebuilt the carb, however the other day, I got to the ramp, and gas was pouring past the primary needle and the engine kept stalling because of it. I drove away from the ramp, went to the parking lot to fix the problem, and it had fixed itself. I put the boat in the water, got it running, and went about 200 yds. When turning moderatly to agressively, the boat would slowly loose significant power, and not really want to recover when straightened out. If I turned for too long, it would eventually stall. The choke horn on the carb has some pitting and junk on it, the accelerator pump screws were destroyed, and the pump arm was bent. The throttles move freely, but not as easily as I would like. I can not get the screws out of the plates without braking them, so I have not cleaned them. My guess is that the secondaries arent opening under load. I may be able to nurse this carb along, But im thinking it might just need to be replaced. Really i dont trust anything the PO touched on this boat. If anyone has a different theory on the loss of power Id be very interested. Thank you Lightfoot |
bill1
Quote Reply
Posted: September-02-2009 at 9:49pm |
after reading all of that, i would want a different carb too.
bill
almabes
Joined: March-20-2008 Location: Acworth GA Status: Offline Points: 263 |
Quote Reply
Posted: September-03-2009 at 11:41am |
Rebuilt marine 4160s can be had in the $200-$300 range. I bought my rebuilt carb for $225 plus $75 core charge.
My core is in decent enough shape it could be rebuilt by someone with the time and motivation to do so. I'd be willing to let it go for the core charge I paid plus shipping. If you're interested, send me an email at amabes at gmcf dot org. |
favorite computer wisdom: net helpmsg 4006
'76 Martinique PCM 351W |
Fl Inboards
Joined: January-20-2008 Location: United States Status: Offline Points: 2255 |
Quote Reply
Posted: September-03-2009 at 12:39pm |
How about a good core 4160 marine and a Renew rebuild kit all for $125.00 plus shipping????
A percentage of sale goes to this web site. Thanks! Jody floridainboards@msn.com |
vondy
Joined: November-29-2007 Location: Dallas, Texas Status: Offline Points: 1116 |
Quote Reply
Posted: September-04-2009 at 11:47am |
Jody I wouldn't mind having a core 4160 Marine. Is it 450 CFM? Does it come rebuilt or just the kit?
That is of course if Lightfoot doesn't want it. |
almabes
Quote Reply
Posted: September-04-2009 at 12:21pm |
Just for the record...My core is a 600 CFM Holley from my 1976 351W. The LIST number is 6576.
I bought a rebuilt one, paid the core charge, and just got busy and never sent in my core. The P.O. of my boat let it sit for a year and the carb didn't like that. So instead of screwing up a rebuild myself, I bought a rebuilt one. If anyone's interested, I can post or e-mail some pictures of it in all it's glory. |
sam57
Joined: December-07-2007 Location: North Canton, O Status: Offline Points: 360 |
Quote Reply
Posted: September-08-2009 at 12:51am |
For what it's worth, I once asked a Holley tech that same question and he told me to put the J tubes in the automotive carb and not worry about it.
Lightfoot
Quote Reply
Posted: September-08-2009 at 8:31pm |
Sorry for being so slow. Things got a little busy. Jody, I am interested in the carb you have, the only thing is that my list number is different. Mine is 50419, and is from an 87 351w. Does anyone know if this will make a difference? If not, this could work really well.
Thanks everyone for the input. Lightfoot |
Joined: November-30-2006 Location: Illinois Status: Offline Points: 14096 |
Quote Reply
Posted: September-08-2009 at 9:42pm |
Get your list numbers all together and call Holley tech support, 270 781-9741. In years past they were very helpful to me.
Fl Inboards
Quote Reply
Posted: September-09-2009 at 10:08pm |
Not sure your list numbers mean a whole lot other than for rebuild refrence. I have a number of core carbs 4160 holley that came off of different year motors all are 600CFM.
The 450 were usally on the 302 ci fords. The price I quoted was for a core and a kit you install and do the rebuild. basicly you need to understand what you are building your carb for. If you are running 36 mph slalom you need to set it up so the secondary's do not come crashing in at the wrong time. If you are barefooting and run wide open you may want to run a different power valve and secondary cam. figuring out the best set up is half the fun with these carbs. Their was a guy named Kevin years ago at Holley that I got to spend a week with as we recaled numerous carbs for different applications. for me that was a fun learning experiance. to bad carbs are not the norm anymore even PCM sells a generic carb that will run on about anything at base settings. |
Quote Reply
Posted: September-09-2009 at 11:24pm |
When I went to a 4bbl carb Jody, I had a choice of 2 used ones. Called Holley and by the list # they could tell what engine they were originally for. I don't know if they could still do that but it would be worth a call.
DrCC
Joined: April-12-2004 Location: at home Status: Offline Points: 2914 |
Quote Reply
Posted: March-31-2026 at 9:00am |
So, ffwd 2026. After sitting for basically 5yrs. My 4160 needs attention.
Instead of messing w/ a kit, thought I'd just plop a new one on for maybe 500.00 or less. Nope, 1200.00. So, I guess it's kit time. |
Jonny Quest
Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3198 |
Quote Reply
Posted: March-31-2026 at 11:17am |
Another slightly less expensive option is the Quick Fuel M-600 marine carb. Under $780. Should bolt right up to replace a 4160.
Post Reply
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
