  New Posts New Posts RSS Feed - 79 SN 351W Prop Selection
jfarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfarc Quote  Post ReplyReply Direct Link To This Post Topic: 79 SN 351W Prop Selection
    Posted: September-18-2009 at 3:12pm
Hey all,
Just went through my first full year of running my rebuilt 79SN after having it out of commission for 2 years. (lucky I bought that searay a few years back so I wasn't high&dry for that long)
After all the tweaking and tuning, I have it running great! I put in a reman'd stock 351W from rapido marine and I am running with these specs:
Full tank gas, minimal gear, driver only
1:1 Trans
13x13 original bronze(I think it's bronze) Prop
4600 rpm WOT
45 MPH top-end on both speedos
0-40 MPH in about 6 seconds
Have really good hole-shot pulling power with skier/boarder/3 tubes w/ 4 riders or with nothing behind boat.
What I'm looking for is a prop that I could go with as an alternate prop when I want to swap out so I can just cruise and get some faster speed than the 45MPH top-end I have now with the 13x13.
From what I know, the higher the pitch#, the lower the RPM & higher the top-end speed. Not exactly sure what a 4-blade vs 3-blade will do for me. I know there's a limit to the pitch so it doesn't put undo stress on the drive-train, but not sure where that is.
Any suggestions?
jfarc
1979 SN 351W LH
13x14 Amce #1459 Prop
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 3:27pm
That speed is pretty good imo....
can you give some feedback on the rapido marine engine? I´ve seen some new members put those engine but non gave any feedback on how they perform...what I know is that they are pretty cheap...
As for the prop wait until the prop gurus show up..they will give you good advise...
seb
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfarc Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 3:51pm
seb,
On your question of rapido marine engines. I did an awful lot of research (they have a complete list of buyers on their website, which I liked, of what engine and when they bought), so I simply downloaded all the 351W buyers and fed the email addresses into a questionnaire I prepared to ask how they felt about rapido and the engine they bought. I got 30+ responses, some issues, but always rapido stood behind and most responses were very good. I know they don't just put happy buyers in the list, because my name appeared on the list the day they shipped the engine before I even received it.
I've put 50+ hrs on it this year and I am extremely happy with the power & performance of the engine. They were cheaper than other places I researched ($1,400 LH Long Block) and very responsive with everything I communicated with them about.
ALTHOUGH, I just put the finishing touches last night on the replacement engine for my '00 SeaRay, which I bought from usengine.com. I decided against going with rapido on the engine (I upgraded from a 305/220hp Merc to a 350/300hp Merc). The usengine website was much more detailed and had more options for these engines than rapido and in talking to both parties about my desires, I thought Mike @ usegine was much more knowledgeable than the folks @ rapido.
I'm going to drop this engine in the SeaRay tomorrow, so I won't know how it runs until I get some hrs on it. You can look at the 2 websites and compare $$$'s, but you'll find rapido was cheaper by $3-400 or more on all engines. usengine had several choices hp-wise for the 351W where rapido only had base stock and they don't even list hp rating for their engines.
Hope that helps.
jfarc
1979 SN 351W LH
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 4:05pm
I ask only for curiosity..as I was looking to rebuild my engine some 3 months ago and it was cheaper to buy the long block than getting all the parts for the rebuild..they even offered the upgraded gt-40 heads for 150+ the list price..
I finally bought the parts and rebuilt my engine, as the import of an engine is pretty difficult to do, I live in argentina..
anyway I added some goodies, the gt40p heads, special cam, edelbrock intake...that will put my base engine that was rated 245hp into around 300hp...haven´t got the chance to test it though as the boat is also under stringer rebuilt.. will finish it by mid october...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfarc Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 4:51pm
Well, very good looking boat you got there, seb. Good luck on the rest of your rebuild.
Give me some info on that pylon pole, if you would please. I'd like to get one for mine. Does it replace the stock short pole or attach to it somehow?
Good weather just broke through, so I'm off to drop that 350 in the searay, so will check back tomorrow.
jfarc
1979 SN 351W LH
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 5:00pm
the skylon (extended pole) slips over the short pylon, so no mod needed in my case..I think that older sytle pylons have the ring and finger so the skylon won´t fit.. you need to take the tip out (cut it or remove it) or you can buy an accesory that attaches to the old pylon and the extension then slip in to it, you can find it here in the store of the site: pylon saver
its around $150
Then the skylon attaches to the bow with a cable
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 6:57pm
Any suggestions?
Sort of a conflicting question but here goes.
As is, your 13x13 3 blade is pushing the boat 45mph, that's respectable for dead stock.
You don't have too many options with your power, if you go up to a 13x14 3 blade you'll be able to "cruise" at a higher speed and lower rpm than with the 13x13 but you'll get no more top end and will drop about 400 rpm. Only advantage to this would be fuel savings but the boat will be slugish out of the hole.
Another option is an Acme 540 which is a 13x12 cnc prop. This one will give you a better hole shot than either of the first two props but will typically spin your motor about 400 rpms more than the 13x13 you are currectly running. It has given most who use it here a 2-3 mph increase but has a negative effect on your fuel consumption.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 7:14pm
I like the 540 on our stock 351, made it like a new boat. Pulls up 4 barefooters deeping up.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 8:44pm
Tim
I would argue that the 540 is the best bolt on performance upgrade money can buy for your boat.
Sam B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2009 at 11:23pm
How much more gas did it use?
Loud pipes save lives!!
2011 Green Lake Reunion Best of Show.
Sam's 73
