Prop spins in neutral |
Brian
Groupie Joined: June-08-2004 Location: United States Status: Offline Points: 72 |
Posted: May-01-2005 at 10:22pm |
Not sure if I have a problem or not.
I have owned an 82 2001 for years and would always start it in the driveway with a hose hook up at the beginning of the season in the driveway to avoid doing this at the launch ramp. The prop on my 82 never turned when the boat was in neutral. I purchased an 86 2001 over the winter and started it this weekend. I was suprised to see the prop spinning. I was able to stop it with a broom but still was surprised to see it move. Is this normal? I am not sure if the conditions under which I had it running had any effect. The stern was elevated due to a slop in the drive and it was pretty cold outside. I looked for a linkage adjustment and didn't find one. Any guidance anyone can provide will be appreciated. |
Brian
reidp
Brian,
This is somewhat common with this type inboard transmission. A good percentage of those I've seen do this, and will then typically do it when in the water as well, and cause the boat to walk or move forward in neutral. As you noticed it can be stopped rather easily and when normal, you can grab the shaft with your hand and stop it. When launched, check to see if you have any water leaking in thru your stuffing box/thru-hull fitting and if so, tightening this will often serve the purpose of stopping the leak and stopping the neutral movement. |
jameski
Senior Member Joined: May-18-2004 Location: United States Status: Offline Points: 368 |
It sounds like you have excellent engine/shaft alignment, providing very little resistance on your shaft. ...OR you might have a worn out strut bushing. But if everything is aligned properly, a little bit of spin is OK.
Brian
Thanks for the response. I will let you know how it acts when I put in the water.
Brian
Brian
Just to satisfy my own nervous nature, how do you determine if the strut bushing is bad?
Brian
David F
Carefully grab the prop and feel for movement. If any movement, replace. Visual inspection works too. Main reason to respond here is to let you know that my friends '86 2001 does the same thing. We both thought it highly unusual and he has lived with it for years now. Yes, the boat sort of creeps when in nuetral, but one person can hold her still against a dock.
Brian
I have a very slight movement, not visible but you can hear it. When you say movement is it any movement?
How big of a job is it to replace. Is is cheaper to buy the tools and do it yourself or just have a marina handle the job? |
Brian
David F
No, you should not be able to move the shaft n the bearing. If you can, then replace the bearing. I suggest you have a prop shop do the work...they have the tools and expertise. If you want to do it, you will need to purchase a tool that pulls the old out and the new in. You will need to look for a set screw and remove it first. Most of the time, the set screw is ground off flush and will need to be drilled out and re-tapped.
jameski
Brian, You might want to check out this other thread: Strut Bushing
There should be a very slight amount of movement if your engine and shaft are aligned EXACTLY right. |
Siveck
Senior Member Joined: March-14-2005 Location: Birmingham, AL Status: Offline Points: 100 |
It could be that your transmission is overfilled slighltly. That will cause the problem that you are describing.
mackwrench
Senior Member Joined: February-25-2005 Location: Gone Status: Offline Points: 190 |
While mine has always "creeped" while in netural, it did "stay in forward" once...Along with being overfull, if trans has any water in it, like cooler leaking, or (in my case) water came in though vent in top of trans (long story), It'll spin like you describe. What a pain, I flushed the cooler & lines, washed the trans out with some diesel fuel but finely got it all out!
NO LONGER A MEMBER
mackwrench
As well, you don't want shaft spinning while boat is out of the water, it'll burn the strut bushing rapid-o As the bushing depends on lake water to keep it cool
NO LONGER A MEMBER
