  New Posts New Posts RSS Feed - Foam Removal
Foam Removal
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Topic: Foam Removal
    Posted: May-05-2005 at 6:46am
Great information guy's. I'll get to work!
64 Skier
66" HO VTX and 67" HO Triumph
71CC
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2005 at 12:41pm
From experience, the foam will dry out IF the floor is removed or significantly removed and the boat is left uncovered (but not in rain) for an extended period. I tested mine by digging a few holes in the foam and discovered it dry to the bottom. I then replaced the dug out holes with pour foam and replaced the floor.
With that said, the new foams are closed cell so you may wish to go ahead and replace all the foam. Some choose to remove the foam and leave it out, but I tend to believe the foam serves two purposes and hence should be replaced:
Bouyancy (sp) and sound deadening and originally a third: structural floor support.
Bill336 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill336 Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2005 at 11:56am
I removed the foam in a 78 American Skier this spring. There is no way it would ever dry out because it was completely enclosed except for at the edges of the floor where the water was getting in. I did remove much of it in the bow at the bottom of the hull and after a couple of weeks, the foam I left above it did drain and dry out.
Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marshall Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2005 at 10:00am
Remove it now! It will never dry out.
'70 Mustang
"Can you hear me now?"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2005 at 9:02am
How long will the foam stay soaked in one of these old CC's. My boats been out of the water for about 6 months and it's time to return home to do some work prior to skiing. Could the foam have dried out by now and make me think I don't have a problem? Should I assume it's OK, ski for a week and then check or should I just remove it while I'm already working under the floor?
64 Skier
71CC
