  New Posts New Posts RSS Feed - rotation question
rotation question
acat600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acat600 Quote  Post ReplyReply Direct Link To This Post Topic: rotation question
    Posted: May-19-2005 at 11:16am
Help me out been so long I forgot. From the front of the engine which is standard and which way is counter rotation? Can I drop in a car crate motor if its regular rotation? Its a 1969 318 mopar now looking to go to crate 360 hi po later if possible. Thanks in advance.
1969 cuda, correct craft of course, mopar fan for life anyway.
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2005 at 11:21am
standing in front of the engine looking towards the rear of the boat. CCW is reverse rotation (RH) CW is standard (LH).
The RH and LH designations come from standing behind the engine looking to the front of the boat.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2005 at 6:13pm
If you turn a regular car engine backwards, the rear seal will leak oil like crazy.
Tim D
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote acat600 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2005 at 10:18pm
thanks.
Bradley950 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradley950 Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2005 at 10:23pm
It shouldn't matter which direction the engine rotates. You will have to index the trans pump. All this means is on the front of the trans, there is a plate that holds the front main seal. Well this plate can be turned 180 deg. It was the position of this front plate that controls the direction of the fluid flow. If the plate is not turned the trans will actually be in reverse while you are going forward. I learned this the hard way. The prop will have to be changed as well. Things can be changed to accomodate a standard rotation engine, just index and prop change!!      -Brad-
Brad Miller
bradley950@yahoo.com
jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2005 at 2:19pm
There are some modifications that would need to be done to an automotive engine. There's a boat building website Glen-L.com that sells a book about marinizing engines.
