  New Posts New Posts RSS Feed - Yeah yeah, more alignment...
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Topic: Yeah yeah, more alignment...
    Posted: April-15-2010 at 11:49pm
I've never been able to get my alignment just right. There's always a gap at the bottom. Seems like if I move the front of the engine down it will fit perfectly. But my mounts do not allow for front vertical adjustments. I only have the wooden wedges in the back.
If I move the back up it's too high and the shaft will bind.
Whats a guy to do?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 1:15am
Grind some height off the stringers at the front mounts?
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 1:26am
Adjust the wedges? isn't that what they are for?
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 4:07am
The wedges are only in the back and adjusting them does not seem to help. You'd think I should raise them a bit so that the bottom of the coupling would move us to get the correct angle but then the top of the coupling is too high.
Again, the front has no vertical movement so I'm kind of stuck. I'll probably try to go with some adjustable engine mounts when I redo the stringers but for now it would be nice to get the alignment a little closer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 8:40am
David,
Loosen the front mounts at the trunion. Flip the angles and rods 180 and make wood wedges to go under them. Get longer lag bolts.
Are you sure your strut to log is good?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 11:11am
David,
That's a pretty good idea. Just might do it.
Not exactly sure what you would consider good but I think it is. Everything looks straight. It turns freely when disconnected from the coupling and in position. The shaft appears to be straight, the gap stays in the same place when I turn it.
Here are a couple of pics I took last year of the underside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2010 at 11:19am
Sorry, did not read clearly about the wedges only in the back.
It seems like those fronts should be the other way around and have wedges, like Pete stated.
Nice shiny pylon!!
Mike N
1968 Mustang
