  New Posts New Posts RSS Feed - 1976 southwind rudder
Bob Egly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob Egly Quote  Post ReplyReply Direct Link To This Post Topic: 1976 southwind rudder
    Posted: June-26-2010 at 8:21pm
I am in need of a replacement rudder for my 1976 20' southwind. We had an unfortunate experience in the lake. The rudder dropped out while running and I have no owners manual to indicate what part number(s) I am missing.
I am looking for any help to locate a rudder and all associated bushings, seals, fasteners, and installation instructions.
Your help is greatly appreciated.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2010 at 10:05pm
Welcome Bob. Here's a link to the original supplier but you'll have to wait for another member with a Southwind to respond with the size you'll need as I don't believe the supplier will know.
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2010 at 12:33am
Bob;
I also have a Southwind, but, I don't know the part # for the rudder. You should call Bruce at N3 Boatworks in Indianapolois. He should be able to help you out. He's a long time Correct Craft parts man.
However, the MOST important thing to do when you get the new rudder on, is to make sure you attach the stainless steel saftey wire in the nut that holds the rudder on, and wrap it around the rudder so it can't vibrate out.
I had this happen on my '87 Martinique. I forgot to put the safety wire back on after working on the rudder port. Not a fun experience!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2010 at 11:39am
A 20' SW will take the same common 11A Correct Craft rudder as most of the larger boats. Everything from the 2nd gen (1970+) Ski Nautique up to the current model, most of the v-hulls (BFN, SW) used that rudder. That should help your chances of finding a used one. Just avoid a rudder from one of the smaller boats (Mustang, Ski Tique, Skier, etc).
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2010 at 1:01am
I'm considering parting out a 1970 Wildcat. Not sure if these rudders are the same?
64 American Skier
62 Classic..
73 Ski Nautique
