92 Motor Rebuild or Replace? |
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
Posted: July-01-2010 at 10:55am |
I am looking at a 92 Nautique. Bad piston Rod, 720 hrs, in boat. Boat and motor in good shape and clean. Starboard head OFF. Pistons look good. Thumbnail opinion? Replace or Rebuild? Guess on cost? Sources for engines? Rebuild with HI Perf goodies? Thanks for your input!!
Js
Whitfield
Senior Member Joined: July-30-2009 Location: Central Va Status: Offline Points: 449 |
What exactly is bad ~ Spun rod bearing? I guess with it pulled down you must go on their word. I'd rebuld what you have as long as the block and crank are salvagable. This way you can specify what you get. When I was pricing marine long blocks last year they ran 2k - 6k. I was skeptical of the 2k units ~ rumor is that some of those remans only replace the parts that are out of spec so you can end up with a hodge podge of multi sized parts. Some parts will have a fresh machined fit and others are just hone and go.
Michael ....
I'm the black sheep ~ 1984 Dixie 299 Super Skier (350 Chev PCM / counter rotation / Velvet drive) Open Bow. |
