  New Posts New Posts RSS Feed - Transmission leak?
Transmission leak?
FrankT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Topic: Transmission leak?
    Posted: July-05-2010 at 8:41pm
It appears that I am leaking fluid on my 10-17 velvet drive from the detent ball. Is this possible? Can the O-ring be replaced on the control valve without removing the transmission?
FrankT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 8:54pm
Frank,
No need to pull the trans! There's a "O" ring on the shift control/spool directly behind the shift lever but, the spool come out from the other side. Be careful on the re install. there's some tabs that need to line up on the spool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankT Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2010 at 11:51pm
Thanks - I will give it a try. Any recommendation on who to source the o-ring from?
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2010 at 8:55am
Frank
I'd go over to my Ace hardware!
