Floor |
882001SN ![]() Guest ![]() |
![]() ![]() ![]() ![]() ![]() Posted: June-09-2005 at 5:42pm |
Hi all,
I have a question... how would you define a soft floor? Should the fooring have any flex in it at all? My floor has some flex around the hollow part between the motor and battery box? Mike |
BigAir ![]() Senior Member ![]() ![]() Joined: March-01-2004 Location: Wis. Rapids, WI Status: Offline Points: 155 |
There should be virtually zero flex. Now, if you weigh in at an extreme amount, even a brand new floor will flex. If it's soft, it will just keep getting worse until you fix it. That's another way to tell. Then again, if you're like me, you might be getting heavier and making it seem like it's getting worse.
Thanks for the reply... No I weight right at 200lb. I just wanted to know what soft floor ment. I will look into what it going on...
Mike |
