  New Posts New Posts RSS Feed - Buffing & Polishing ...
damonwells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote damonwells Quote  Post ReplyReply Direct Link To This Post Topic: Buffing & Polishing ...
    Posted: July-12-2010 at 4:25pm
1990 SN, gelcoat in excellent condition. Wondering if I can use a Milwaukee Sander/Grinder #6148 with mandrel and 3M wool buffing pads to buff Perfect-It and Finesse-It products ? This is not a variable speed machine.
I will probably work the compounds by hand and use the Milwaukee for removing product and polishing.
thanks, cheers, John
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 4:29pm
John,
It's too fast of a RPM. If the gel is in good condition, how about just using one of the "cleaner" wax's then it's all hand work. 3M Marine is a good one.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 4:43pm
You would need the Milwaukee #5455 or slower.
AT
Hawktique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawktique Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2010 at 6:42pm
Just finished Sanding and Buffing my '90. I used a variable buffer purchased from harbor freight for like $45, worked great. I listed the link to the thread for you with the info on the materials I used after lots of research on this site.
"A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
