Another No Start Thread |
Post Reply | Page 123> |
Author | |||||
flipflop
Senior Member Joined: June-15-2010 Location: usa Status: Offline Points: 187 |
Posted: August-17-2010 at 12:22pm |
Kind of stuck and need some direction…still not Firing.
Previous Post Field Notes… I have tested my voltage and it is up to 11v at the ignition and 9v at the coil. I know that is a little low, but I was able to get a spark with the new points and condenser I put in. I replaced the fuel pump and filter and have good fuel flow to the carburetor. The carburetor was leaking and had to JB weld part of the secondary fuel bowl. It’s still leaking a little from a broken o-ring on the fuel line and I need to find a new one (any suggestions), but I feel I should at least be getting some response out of it. The engine still isn’t firing and I’m not sure what to do next. o My engine is a 1989 351 – PLD PR R18 – Left hand or standard rotation. o Prestolite E5JL Distributor – New autolite plugs. o Checked firing order – from serial number – 13726548 Thinking out loud… o Try to get more volts out of ignition wiring. o Replace spark plug wires as old ones are a little worn. o Firing order not starting at TDC. o Problem with my carburetor. o Looks like it is letting in fuel. o The electric choke seems to be working. o Problem with engine. Back of mind… I thought about brining it to a mechanic, but my goal was to get it fired up myself. I know it’s possible, maybe you could recommend some reading material or share some knowledge. If you have any questions, see my old thread or ask. I’ll be around. Pictures |
79nautique
so how many volts are at the battery?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21136 |
Before we all go barking up the wrong tree, can you clarify? Your previous post said you were getting some spark, which would indicate that the boat is cranking (turning over) just fine, but is not firing. The former would have us checking the battery and starting circuit, the latter would have us diagnosing the ignition system... big difference. |
flipflop
Sorry for the bad terminology. Engine is not firing. I am getting some spark, but the engine is turning over via starter. 12v at battery, 11v at ignition and ballast resistor, 9v at coil.
When you say 11V at the "ignition", where exactly are you measuring?
If your spark is weak, I might be inclined to "hot wire" from the breaker to the coil + while youre testing. This will take voltage drop issues (corroded connections, etc) as well as the ballast resistor out of the picture for the time being. If it runs well like this, you can go fix those issues. If not, at least theyre not compounding another problem. First, move the the motor to TDC on the compression stroke. It helps to have a breaker bar with a 15/16" socket, but otherwise you can bump the starter. Put your finger over the #1 plug hole to determine which stroke youre on (compression stroke will push your finger off the hole). |
behindpropeller
Do you have an emergency tether on the boat?
79nautique
untill you have a good battery in the boat and repair the wiring harness connector's terminal that's gone your not going fix a damn thing
flipflop
TRBenj - I will find TDC and adjust my wires accordingly. I've been reading more about timing and starting to grasp the concept.
Behind Propeller - Thanks for the advice. I am trying not to hurt myself. Keeping all gas away from the engine. 79 - I've read a lot of your posts and hoping to sway you into helping me. The battery is new and reading 12v and has 650 cca. It may be a little weak from all my testing, I should get it charged, but do you think thats really it. If so, I'll go charge it. Maybe I can repair the wiring harness. I'll look at that again and see what my options are. It would be nice not to have to replace it. |
It cant hurt to charge the battery, but I doubt its your issue if the engine is cranking reliably.
I think BHP is asking about the safety lanyard because theyre known to come unhooked or become intermittent, preventing an engine from starting. An '89 should not have the lanyard (at least it wouldnt have had one from the factory), and youve got spark- so I dont think thats an issue... but if you do have one, you may want to verify that its working properly. If youve got spark and fuel, its more likely that youre simply out of time. I would get your firing order and timing straightened out first, then make sure youve got good, consistent spark. Out of curiousity, did you replace the ignition switch as Pete suggested in your previous thread? |
79nautique
13.5 volt is a good battery 12.5 is on it's last leg. and it doesn't matter how much voltage it has if the connections are corrioded or missing or the cable are undersized. There's areason your readings are low every where and it starts ate the battery then moves through the wires and on down the line.
behindpropeller
Flip Flop- Answer the question. Does your boat have an emergency lanyard on it? If yes... It is the first thing to check. |
flipflop
Yes, it didn't change anything. It was $40 at West Marine so I took it back.
If it was a safety lanyard problem, he wouldn't be getting any power the the ballast resistor and coil.
79nautique
so you want to over look all the crappy connections that are corrioded or missing, all the low voltage readings all over the F place, please you call your self a EE, what a joke your becoming with your advice. |
behindpropeller
Pete- Will an engine fire without power to the resistor and coil? |
If he is cranking reliably, then his battery and connections in the starting circuit should be good enough for now. It never hurts to clean them, but they arent causing any of the problems described. Like I said, it wouldnt hurt to run a jumper from the coil + to the breaker- this would eliminate any bad connections in the ignition system, as well as the ballast resistor.
Better learn to read more closely. |
Tim, Of course not! He however stated he's got power!
flipflop
79 - We've spent a lot of time cleaning the battery terminals, connections, etc. The volts are as high as I can get them atm. The voltage loss is somewhere between the ignition switch and the ballast resistor. It will take some time for me to really get the volts up as I learn the electrical system. I will return the battery because it only had 12v when I bought it. I need to research the missing part in the wiring harness. It looks like there was never anything there or it was removed because it was so corroded. I might be able to drop a new pin in there to create a connection?
Behindpropeller - Sorry, thought you were making fun of me. As you know, my terminology is bad. It doesn't look like there is a safety laynard switch. TRBenj - I'm leaning in your direction. I will investigate the timing and report back. I took my measurements with a multimeter at the ignition switch, ballast resistor, and coil (and everywhere else I could). I will try and bypass everything directly to the coil once I get the timing and firing order worked out. |
What did you end up doing with that VERY bad looking engine wiring harness plug/connector that was all burnt up and corroded?
79nautique
try looking at the other thread for a change, hard to fire a coil or a spark plug with 6volts. A main engine connector that is oxidized and missing a terminall all together hell yea your getting all tons of current and voltage going throught the connections that's why there is 12v at the ballast and coil and why there is just enough voltage to spin the starter but not have enough energy to fire the plug. a yellow spark at the plug might work on your lawn mower but it not going to cut it on a real engine. |
flipflop
8122pbrainard - It actually cleaned up pretty well. It doesn't look like I'm losing any volts there. Any change at the ignition switch is shown at the ballast resistor. I will take some pictures and look at it again tongiht. I just figured I was able to get a spark so I moved on.
It looks like I need to retrace my steps a little and pay attention to the details. I know its not going to be a a clear simple path to get the boat running, but I'm going to keep trying. I am trying to use this forum to keep me in line with where I need to be. Thanks. 79- Good point. I am going to go back and check my plugs for consistent reliable spark. My voltage is up a little from when I started. Should I consider replacing the coil? |
behindpropeller
Pete- Typically when a guy trips the lanyard it will actually start for a second. Thats from my experience on two different occasions. Carry on though. No reason to check something simple like a safety lanyard first. Tim |
79nautique
replacing the coil isn't the issue the issue is you don't have enough voltage, this starts at the battery, then to the wires, the connection might be clean but the rest of the wire can be junk under the insulation where you can not see it, so if you not getting the same voltage reading within a .1 or so volts from the start of the wire to the end of the wire then the wire needs replaced, or the connection need cleaned depending how you are checking them, connected or disconnected. |
Tim, This would be typical on a Indmar due to them using the ballast resistor by pass to the coil from the start relay. Were they Indmars? |
9V to the coil (through the ballast resistor) should be plenty for the points. If you read closely, he's already cleaned the connections and has consistent voltage from the ignition switch to the ballast resistor. I am confused why the switch wasnt replaced since there was a voltage loss through it, though. I dont believe (once cleaned) there is anything wrong with his harness. On boats with voltmeters, I believe the alt feed (orange wire) pin is unpopulated in the connector and is tied to the hot feed (red wire) internally on the engine side of the harness.
Long story short, I would do just as I suggested in my first post in this thread. Bypass the resistor and then verify the timing. |
79nautique
hey fool, doesn't mean a damn thing to have 9 volts at the ballast if your only getting 6 of those 9 volts to the coil dumby , last time I checked you need voltage at the coil for it to fire and the ballast doesn't even have to be hooked up for it to work. Better work on your reading skills and read all of the detail. all your creating is another tail chasing exercise again. You loss credability daily. TIMMMY GO BACK AND READ I HYLIGHTED THE CRAP FOR YOU. |
I can read just fine, Chris- can you?
From the first post in this thread, after he cleaned his connections:
Who is the one causing the tail chasing? |
flipflop
TRBenj - I did not replace the switch because it wasn't causing the drop in voltage.
I seperated the three purple wires coming off the switch and tested each once individually and paired. On one of the tests, I was able to get the 12v from the battery to go through the switch without losing voltage. That's why I was thinking the voltage loss was somewhere between the dash and the ballast resistor. |
79nautique
YOU NEED TO LOOK A LITTLE CLOSER SLICK. so bypass the ballast add more juice to the coil and it'll fire if that's the issue, doubt that it will thought. |
flipflop
79 - What about his response to the missing connection in the wiring harness? This would make sense because I didn't look like there was a connection there in the first place?
Not to say there isn't something eles going on and I doubt it will start. As thats just the way its going, but I want to at least find out where TDC is so I can ensure my wires are set up properly? |
