  New Posts New Posts RSS Feed - motor box 1985 sn2001
bigeasynauti View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigeasynauti Quote  Post ReplyReply Direct Link To This Post Topic: motor box 1985 sn2001
    Posted: June-23-2005 at 6:29pm
have damage to front right corner of motor box anyone know where i can get another?anyone know what the timing should be on 1985 351 pcm with prestolite distributor upgrade?
jcawley3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jcawley3 Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2005 at 10:50pm
i was told 8 degrees over ? works good on mine
backcrkr View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote backcrkr Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2005 at 1:11pm
on the box issue, depending on the dammage you might could repair it with some coats of fiberglass. I had an 84 that flipped on the interstate(long,sad story)it crackek the box pretty well but it was set in place and re-glassed and is probably stronger that before.
