  New Posts New Posts RSS Feed - Cracked Heads
Cracked Heads
1993 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1993 Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Cracked Heads
    Posted: September-08-2010 at 3:45am
I have a 1993 Nautique, the heads are cracked and leaking water on the outside of the block. Any suggestions on where to purchase a new set of heads? It's a 351 Pro Boss.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2010 at 10:35am
welcome..I'd suggest buying gt40p heads..they are a little upgrade over the stock gt40 of yuor engine...
if you want to keep your stock camclearwaters cylinder heads
if you have cam upgrades in mind tristate cylinder heads
if you go for any of these heads you should specify they are for a 351w marine engine..they will drill the heads bolt for larger size and put brass freeze plugs...
as for the post better post it in the engine repair section..
it will get more attention than here...
good luck
<a href="">1992 ski nautique
