  New Posts New Posts RSS Feed - Nautique Speed
Nautique Speed
Titanjets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Titanjets Quote  Post ReplyReply Direct Link To This Post Topic: Nautique Speed
    Posted: September-27-2010 at 12:47am
Hi everyone,
I have a sweet 83 Ski with the standard 351. It runs @ 43 mph and 39-40 with a barefooter behind her. I need to get 5 to 8 mph more for the very hard water that I like.
Is there any way to amp up the 351 for a few extra mph without digging in to deep? I currently have the ACME-540 Three Blade.
Thank you,
Titanjets
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 12:58am
How much do you weigh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Titanjets Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 1:21am
210 lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 11:39am
8mph might be pushing it but 5mph should be easily doable for $1500 or a little less. A good head/cam/intake combo should add about 80hp and make that boat an even better skiing machine. The proven 351w recipe around here involves GT40p heads, an Edelbrock Performer intake and a Cam Research cam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 3:40pm
Did you notice Titan's address. He's got some neighbors that could probably help him out.
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 3:46pm
Titanjets, welcome aboard. Are you both a Titans and Jets Fan??
The intake,cam and heads combo is the way to go, you know bang for the buck with out stepping up for big $$$$ Performance gains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Titanjets Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 8:16pm
Aviation related handle…Thank you for the performance info…
With the cam replacement, is that a major engine teardown?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 8:35pm
Not a to a tough job, it is better if the motor can come out of the boat and get set on a skid or motor stand, But if you choose to do it in the boat the pylon will have to be removed and that one could be chore in it's self, But all and all provided you have all the tools and new parts and associated other materials one could pull it out of the boat in the morning and go skiing in the afternoon.
However if you have never done this before then it would be good to either read up on it, I am sure some one has documented this typ of work on this forum or bring in a specialist to help you out.
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2010 at 10:09pm
You'd better believe it! Race City Marine (your new local Nautique dealer) loves to make Correct Crafts run faster and could help you out, IF you needed someone to perform the work for you, and CCFan folks do get the neighborhood price. We have the GT40P heads in stock right now as well. You can call me at 704-451-5080 if you like. Everything said above is spot on by the way in terms of achieving your goals.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 11:58am
Does Race City Marine do mail order?
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:21pm
Of course Bruce, but not for a cam, heads, and intake swap. Oh, but I guess we could ship the parts.
ReidP
1973 Mustang
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2010 at 6:47pm
I wonder why no one got the water logged foam issue into play also...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Titanjets Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2010 at 10:34pm
This boat was and is garage kept. Pre-purchase inspection showed dry foam and a solid floor. A big factor in my decision to purchase. Boat doesn’t see much sunlight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2010 at 12:34am
so the h-c-i is the way to go...
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2010 at 2:02pm
Why not? Have them UPS the engine, you replace the parts and ship it back.
When I owned my blow boat marina A guy at a boat show asked if we could fix a hole in his Sunfish. I said sure no problem. He asked if he needed to bring me the boat? With a straight face I said no, just send me the hole and we'll fix it and send it right back to you. The guy I was with had his milkshake comming out his nose trying to contain himself. The Sunfish guy walked about 10 steps turned smiled and said, Hey you were kidding weren't you? Then we all lost it.
