  New Posts New Posts RSS Feed - Viberation - was driving at speed.
brettmcox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmcox Quote  Post ReplyReply Direct Link To This Post Topic: Viberation - was driving at speed.
    Posted: June-01-2011 at 11:42pm
On a weeks trip and i was driving my 86-2001-sn with 351 and 11.5p prop. then i got a crazy Viberation. I do not think i hit somthing, but cannot be 100%. prop looks good but just looking with my eyes. Shaft seams ok but might have a slight bend, but could just be my eyes. i know my packing nut was dripping more before this Viberation started, but it did not stop...
I was driving at 2200 rpm no load and in the middle of the lake. did not see anything around. then started to shake. little or no shake at low speed.
if i hit something could the shaft took all the bang and prop missed it?
Could shaft had the bend but i never looked for it and tranny is having the issue?
Could be be a motor thing?
Thanks!\
brett
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 12:39am
Brett - I have gotten similar sudden vibrations & I think it was fishing line or seaweed, as it went away when I stopped & put it in reverse.
1st - check to make sure your prop is not loose & the lock nut & cotter pin is there.
Then check your shaft coupler & screws to make sure those are tight.
When something changes suddenly, it is usually a simple cause.
PS - Last year we hit a log & it bowed the shaft but did not harm the prop. Hard to believe but true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmcox Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 2:43am
Then check your shaft coupler & screws those are tight..
I should know how this is done, but can I get a 1, 2, 3 on this. Or a link. Only have phone and not the best edge wireless coverage.
Could my strut bushing broke.... It all seams tight...
Prop cotter pin still there.
And thanks
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 2:47am
you would definetely feel if you hit a log or something strong enough to suddenly make the boat vibrate...
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmcox Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 3:00am
That is what I think, but.... I have never hit a log, rock, fish or.... At speed... And yes I have been boating for 35 years.... but only had inboards for 3 years all otheres are I/o and obs
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 9:49am
you may be experiencing shaft whip also, slight bend but aggravated by RPM's
Post Options Post Options   Thanks (0) Thanks(0)   Quote brettmcox Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2011 at 4:28pm
Swapped the stock 13 13 and I think I hit something.... But I will test more later.
spiralhelix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 1:52pm
Thought I would continue this thread instead of starting another.
I'm having similar issues as this post. I have done my usual google search "correctcraftfan.com sudden vibration", which usually gives great results, but only came up with a couple threads. Another one here but that is almost the opposite of what I experienced. And and this one here is almost to a T what happened to us yesterday.
I have come here today just to verify that i will be attacking this in the proper way, aka testing and not throwing parts at it!
so our story, after about an hour on the river, we were traveling at 23 mph in a straight line and instant vibrations. immediately reduced throttle to neutral with no vibration. put it in reverse (detent, no additional throttle), without vibration. Everyone on the boat all said the same thing, "sure didn't feel like we hit anything." The vibration is only evident over 1.2k rpm, but never pushed it over 2.5k as i was afraid it would cause more damage. Idled back to marina. prop "looks" fine. drive shaft "looks" fine. spun the prop/shaft and didn't "feel" any binding or notice any bends in the shaft. Engine revs up in neutral without vibration. Popped the access panel and you can definitely "see" the vibrations in the rubber coupler just aft of the stuffing box.
1. So my first step i will take is to check prop nut for tightness and/or change out the prop to make sure the prop itself isn't unbalanced (the testing prop when last used caused no vibrations).
2. Based on the other thread, i can check for water in the fuel. Not sure how to do this, so I'll keep looking through other posts.
3. Check shaft packing, shaft coupler screws.
4. Check cutless bearing (not sure how to do this)
5. Check shaft alignment? Any recommendations for the best tool and where to get it? do places "rent" them? I've prolly watched Pete's video 20 times when i first joined this site, so at least I'm somewhat familiar with that resource. If this ends up being the case, is the only solution a new drive shaft or can a machine shop straighten it?
And just for piece of mind, are the symptoms generally shaft/prop issues or could this be a transmission issue? And if a prop/shaft issue, can the boat still be used at least at 20 mph or less or would the continued vibrations lead to further problems/damage? Not that I won't fix whatever is wrong, but with the holiday this weekend, we want to be able to cruise the river with the family.
Thanks in advance for any feedback.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 2:43pm
Well, best to use logic to figure out what could change going along at steady state.
Is your Tranny fluid OK?
Any engine mounts work loose? (this happened to me, obviously I didn't lock them tight enough).
Definitely check alignment & cutlass bearing. Maybe even check packing gland, I have heard of these rubbing the shaft on the inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 2:44pm
Joe,
Since you mentioned you didn't notice any binding of the shaft, I'd say the alignment is good but it's a good idea to check it anyway. After you check to make sure the prop was seated properly to the shaft, the next two suggestions are to check the shaft for straightness and have the prop checked. Both can and will go at anytime seemingly for no reason and without hitting anything. Shafts are known to completely break off and typically just aft of the strut. Check the shaft at the tail end with a dial indicator. Anything over .003 isn't good.
Bad alignment typically does not cause vibration. It actually has the opposite effect sine it's putting a bind on the shaft snubbing vibration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 2:51pm
I'm guessing you hit something... I've seen props that look ok but are totally out of whack once you put them on pitch blocks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 3:10pm
yes, tranny fluid was still ok. I actually check that before we leave the marina each outing (along with the oil). But did check it right after "the event" just to see if it had been leaking or anything and it was still at the same level. Blige shows no sign of leakage either.
After reading Pete's post, i misused the term alignment in my head. I realize now there is alignment with the tranny, but I was actually thinking shaft straightness. What is a recommended dial indicator and/or can i rent one from an auto store? if it is off the specs, can a shop straighten it or is it a new part purchase?
Tim, yeah, i would agree, i haven't ruled out the prop and prolly the easiest to test. However, the props have recently been repaired and were in waaaaay worse shape without vibration. I also didn't rule out that we hit something, but there wasn't any sort of thud, jerk, bump. The speed of the boat never changed, just the sudden vibration. Enough the back floor was vibrating.
We were with another couple and it was getting late, so I didn't spend a lot of time investigating. Just a quick look and spin of the prop and looked over the hull for damage. I plan on doing things the best i can in the evening, but any water tests will have to wait until thursday.
Thanks for the quick replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 3:51pm
Joe,
I'm not sure if an auto supply would have a dial indicator?? I have a real cheap one from HF that I clamp to the strut. Yes, you can straighten a shaft but, with the advent of the ARE shaft system, I personally don't feel it's worth straightening. The R&R of a single taper shaft is a real PITA due to the trans coupling half being a press/shrink to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2016 at 6:23pm
Thanks Pete. Glad to know cheap is ok here :)
I'll go through as many steps as i can tonight if time allows. The SeaDek for the bow arrived today, so that might get done as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 12:17am
1. Prop-Nut was tight, prop was seated firm and took three good whacks on the puller before it popped off.
prop that was on during vibration:
testing prop next trip out:
2. Check cutless bearing. When pushing up/down/left/right on the drive shaft, there was no movement inside the strut. I'm gonna call that good for the cutless bearing?? The vids below might be more telling though.
3. Check shaft straightness: You tell me. The tail has very little movement and i'm guessing the main shaft is within specs. I'm just not sure if i'm reading the numbers correctly. You may need to "watch in YouTube" to see the numbers better. Sorry about the tail angle too, but it looked like the dial only moved two tics. After watching the vid of the tail, there is a noise at the same spot during each rotation.
Dial setup (a friend had one that he let me borrow):
main drive shaft video link
tail drive shaft video link
4. Tranny Fluid
Checking next unless you feel like one of the above is the issue.
5. Water in Fuel: not tested yet.
6. Check shaft packing, shaft coupler screws. not tested (limited time tonight)
7. Engine Mounts. checking tuesday night.
8. Shaft Alignment at coupler. checking tuesday night
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 6:50am
Joe,
Your videos are marked private but, your pictures are enough for me to comment. I should have been clearer on where to read any runout with the dial indicator. I mentioned "tail" end but I should have said at the very end of the taper just before the threads. The spot were you are taking the reading is where the shaft typically bends so if the shaft is bent, you wont see any or not much runout. Each "tick" is 1 thousand .001" Since you are getting 2 ticks just aft of the strut, then I suspect the shaft is bent. Reposition the dial indicator and report back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 9:11am
The part of the shaft Pete is talking about would be smooth as well. From the second video is almost appears as if there is a scratch or burr on the shaft that the indicator may be reading.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 11:09am
vids fixed.
good catch on the burr. glad i took the video. you can see so much more than when initially doing it. I can move the dial, but the keyway slot is only about a 1/4" from where the dial is now and thinking about it, i have a picture in my head that the slot extends into the first part of the treads. but i could be wrong so ill check again tonight.
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 1:12pm
Make sure the prop isnt riding the key.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 2:38pm
Spray some soapy water on the cutlass it will make turning the shaft a lot easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 10:28pm
soapy water worked great.
tail runnout
So it would appear that the swing is about -1 to +4 so 0.005" ........ guess that means the shaft is bent.
Unfortunately a new shaft isn't really in the cards right now so this might be the end of the season. Is the probability high that continued use at or below 15 mph (mainly idle speeds up and down the river) would cause the shaft the break with one more 2-hour outing with the fam (four adults) on Sunday?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 11:36pm
Joe,
I would concur that the shaft is bent. Did you sent the prop out to a prop shop? If so, report back what they find. It may not be the end of the season yet since depending on what they find, it may be worth taking a chance.
LeftFieldEngineering View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2016 at 11:54pm
Some machine shops can press or heat straighten shafts. Before writing off the season call around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2016 at 12:24am
Well, i have a few things going against me. I had both the 3 and 4 blade props repaired mid-season last year. The prop guy i used is up north in GB and i have no plans to head up there (so i'd have to ship it). I've been using the 4 blade, so at least the 3 should still be good to go. I'll still test that out on Thursday.
As far as a machine shop, the one in town has already been working on a new set of ex. manifolds for the past 2 months. Apparently he is really busy, soooo I'm guessing this wouldn't be high on his priority list. All other shops would be drive time, which i don't have that much of during the week.
Plus, the Mrs has already put the kibosh on extraneous boat expenditures, it was hard enough to work fuel into the budget (at least I won fuel). I can't comprehend how she won't put boating above groceries????
I'll probably take my chances over the weekend as at least in idle gear there wasn't vibrations. Just need to make it to the anchor spot and back. It'll probably be a few weeks before i get answers to the rest of it. I guess now is a good time to install the SeaDek in the bow. Stay tuned for that thread
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2016 at 12:17pm
There are guys parting out the 2001 hulls on this site. what about obtaining a used shaft from one of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2016 at 12:37pm
Eek, I guess I would have saved my money on the SeaDek if the boating budget was THAT tight.
I'm sure I have at least one used 54" shaft I could sell. Bring your nifty dial indicator and come measure it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2016 at 12:43pm
HW are we talking about the same thing?
The seadek was purchased before all this happened. I'll message you to see what we can work out.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2016 at 12:49pm
you might want to bring lube
or not
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2016 at 1:09pm
I'll bring a 1/2 rack. No matter how it turns out, at least I won't remember it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2016 at 12:18am
Well, got some good news to night. Took the boat out for 45 min. Started slow. No wake speed, then we just kept bumping it up 100 rpm at a time. Noticed a little vibration in the exhaust hose, no vib at the rubber coupler. Got it up to 2500 and still no vibration like before. Then got it up to 4000 without issue. Took it back to 3000 and ran for a good 30 min like that. Seemed solid the whole time. So im gonna say our issue was the prop. Still gonna try and get a shaft for a spare. 4-blade is already on its way to the shop to be tested. Thanks again for everyones help.
3-blade test
