Idle fuel adjustment screw |
jeffro28
Groupie Joined: February-05-2011 Location: greensboro nc Status: Offline Points: 67 |
Posted: June-04-2011 at 12:35am |
Hello everyone can anyone tell me the correct idle fuel adjustment screw setting {85 sn 2001 holly carb.} and is it the same for both sides? thanks Jeff
Luchog
starting at 1.5-2 turns out, the one allowing max vacuum at idle
GottaSki
Done While in forward gear is best
River Rat to Mole |
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
always start on one side then do the other then redo the first. ( if you meant the fuel mixture screws.)
Morfoot
Yep I second that only because the Doc came flying out of his cabin told me to lash " Miss Scarlett" to the dock put her in gear, hand him a flathead screwdriver and then he worked his magic. Five mins later after she was tuned up and purring like a kitten he turned to me, looked at me square in the eye stuck his hand out and said " Billy Sutton....boatdr...you must be Tim Morfoot" hand shake turned into a hug and we've been buds ever since. |
jeffro28
Thanks guys for the info
