Pylon Trim |
vondy
Platinum Member Joined: November-29-2007 Location: Dallas, Texas Status: Offline Points: 1116 |
Posted: June-10-2011 at 10:41pm |
Does anyone have an idea for some kind of trim piece for my pylon hole? At the moment it will be just pylon against the new vinyl flooring and ply below.
Thanks! |
David,
You've been putting in so much time on the boat, you haven't been doing your "homework".
Pick up some aluminum about .125" thick. |
vondy
Not a bad Idea Pete, thanks.
Yeah if I'm not at work, eating or sleeping, I have been working on the boat. Getting up early, staying up late. I'll update with some pics soon. |
You could go that route David,but I myself would rather keep it more original,unlike that last poster Mine has 3 holes,3 1/8" in diameter and .100 thick
DrCC
I believe I have one.
vondy
Gary did you make that or did it come with your boat? Do these have a cup that fits down into the hole or is it simply a flat trim piece? Dr.CC I'm interested if you have one. I believe the my pylon is 1 3/4 inch diameter. |
David,
They are just a flat plate. Yes, you better go original with 3 holes instead of 4 and .100 aluminum is 10 ga. |
DrCC
I think the one that I have is just an ordinary Perko trim ring.
It is a 3-holer. |
Mine is the original one David,it's just flat with a radius on the outside edge so that it's not sharp.
David,
I almost forgot - when you install the 3 hole ring, make sure the one screw faces forward and the other two are aft just like Gary's. We do need to keep things original here! |
DO NOT line up the crosses on the phillips screws,Correct Craft was not that detail oriented.Remember production boats not custom one offs
