1971 Crusader 351 Exhaust Hose |
dag5303
Groupie Joined: March-05-2007 Location: United States Status: Offline Points: 53 |
Posted: July-30-2011 at 7:40pm |
Starting restoration of green 71 Ski Nautique (photos in diaries) Dazed and Confused.Replacing exhaust hose with old style wire reinforced 3" ID. Back exhaust pipes exiting boat through transom are 3". Problem is exhaust dumps off manifolds are only about 2.5" OD. No way this 3" wire reinforced hose will tighten down on these exhaust manifolds. How was this done from factory?
Thanks Dave |
DrCC
With a short piece of 2-1/2" ID smooth wall hose.
dag5303
Thanks DrCC
To clarify, I should put short "sleeve" of 2.5" ID smooth wall over manifold dump and then just put 3" OD hose over 2.5 " hose and tighten down. |
dag5303
The short piece of 2 1/2 ID hose as a sleeve worked great. No problem working 3 1/2 ID over the top for a tight fit.
THANK YOU |
Double clamping is preferred and a USCG reg below the water line.
storm34
What manifolds are on that boat?
This boat? |
dag5303
Sorry we seem to be photo upload challenged. The manifolds are straight w/o camel hump at back end. Collector is about a 60 degree downward angle ending up in 2.5 inch OD. Casting # are 1103(?) 982 and
