  New Posts New Posts RSS Feed - Manifolds
Manifolds
NL SKI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NL SKI Quote  Post ReplyReply Direct Link To This Post Topic: Manifolds
    Posted: July-31-2011 at 3:00pm
I run my boats in water with a lot of calcium in it and my manifolds are full of little hardened calcium flakes. I was wondering if anyone had any ideas on how to get it all cleaned out of them? I thought I heard someone say something about boiling them out one time, or I was also thinking about soaking them in some kind of vinegar or lime away. Let me know what ya'll think??? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2011 at 4:28pm
I have seen manifolds and risers used in salt water cleaned out in muriatic acid to get rid of rust,you just build a box line it with plastic and submerge them.I would think you could do the same with sometning like limeaway or clr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2011 at 5:50pm
Nick,
When you mentioned "boiling", You're probably talking about the good old days of the caustic hot tank where many an engine block would go. Those have pretty much disappeared due to the GD EPA!! So, one thing you did not state if if you truly have a cooling problem?? No cooling issue - no problem!!!! What temps are the manifolds running at? Did you IR scan them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NL SKI Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2011 at 7:22pm
Oh yeah I'm having some cooling issues!!! The first time I had a burned head gasket between number 3 and 4 cylinder and a cracked head. Did all my back breaking work and finally found another GT40 head and put it all back on ran it for about 8 to 10 hours total engine time and no compression in number 2,3,4, cylinder. The temp gauge on boat was working showing 160 all the time and Cylinders 4 though 8 are fine and cool as cucumbers. I'm either thinking its a fuel rail blockage causing it to run real lean over there or my manifold? So I'm going through the whole thing just to make sure I don't smoke another head. THank you guys for all your advice I really like this site!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NL SKI Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2011 at 7:24pm
Oh yeah my machine shop guy had the new head in his shop 4 days before said no cracks and when I took it back he found 9 cracks in it!! So something is getting really hot and I don't have a IR scan but I will have one the next time we fire this bad boy up.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2011 at 7:43pm
maybe the block cooling passages are blocked and some areas get hotter than others.
